587,189 active members*
2,623 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Tool Offset and Work Offset Locking on Fanuc OiMD
Results 1 to 10 of 10
    May 2008
    157
    We have a few VMC's with Fanuc OiMD controllers. I want to lock the tool offset table and Work offset tables in production runs once the first part is proved so that the operator does not fiddle with the offsets. I dont want to switch off the edit key for this purpose as there will be requirement of program editing.
    Is there any way to do this by updating some parameter on the machine using G10 L52 command OR something on these lines ?
    Thanks a lot in advance
    1792
    Re: Tool Offset and Work Offset Locking on Fanuc OiMD
    I am not sure, but I believe it is not possible to lock these with some parameter or system variable.
    May 2008
    157
    Here is some Info I was able to dig out :
    DISABLE TOOL OFFSET MANUAL ENTRY
    #3290
    BIT 1 : OFFSET ENTRY DISABLE
    BIT 0 : WEAR ENTRY DISABLE
    #3294 : START TOOL NUMBER TO DISABLE
    #3295 : LAST TOOL NUMBER TO DISABLE IN THE RANGE STARTING FROM #3294
    Nothing yet on work offset.
    1792
    Try 3290#3 = 1
    May 2008
    157
    This one works to lock all the work offsets. Thanks
    My plan was to selectively lock the work offsets like in the case of tool offsets ie. I want to lock from G54 to G57 and keep G58 and G59 open. I think this is not possible going by what I could gather from the parameter manual for #3290.
    1792
    Locking geometry/wear offset numbers in a range is possible, but work offsets cannot be selectively locked.
    You are correct and you can use G10 L52 to "lock" your G54 thru G57
    G10 L52 ; Parameter entry mode
    N1221 R123.456 ; G54 setting
    N1222 R123.456 ; G55 setting
    N1223 R123.456 ; G56 setting
    N1224 R123.456 ; G57 setting
    G11 ; Cancel parameter entry mode
    Parameters:
    1221 G54
    1222 G55
    1223 G56
    1224 G57
    1225 G58
    1226 G59
    1792
    That is an intelligent method.
    Find out the values stored in G54 etc and insert the suggested lines in the beginning of the program.
    Any change in work offsets would be overwritten with the original values.
    May 2008
    157
    Quote Originally Posted by drdos View Post
    Parameters:
    1221 G54
    1222 G55
    1223 G56
    1224 G57
    1225 G58
    1226 G59
    Thanks a Ton drdos That was a very good piece of information.
    Jul 2015
    The following parameters can help you prevent "fat finger" mistakes:
    #5013 : Maximum value of tool wear compensation
    #5014 : Maximum value of incremental input for tool wear compensation
    My favorite is
    #3290.1 : Setting the tool geometry offset value by MDI key input is 0 - No disabled, 1 - Disabled.
    Don't test on all controllers but looks like it should work at 16 and newer.
    Let me know if you have any questions.
  1. Tool offset with work offset
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 06-04-2012, 06:31 PM
  2. Tool offset with work offset
    Last Post: 05-28-2012, 09:52 PM
  3. Tool offset with work offset
    Last Post: 05-28-2012, 09:48 PM
  4. Fanuc 6M-B Offset setup both work and tool
    By RAJCKAM in forum Fanuc
    Last Post: 08-18-2010, 06:17 PM
  5. work offset in fanuc 6m b- help
    By rags in forum Fanuc
    Last Post: 08-04-2006, 03:39 AM
