I made my laptop a dual boot to XP and loaded mastercam v9 I had and want to learn. I installed it and the Design 9 works fine. The other 3 parts however don't seem to be working properly. When I try to run the Mill for example it says " Warning - error opening F:\Mcam9\temp\db.ovf" then when you click ok it says "not enough memory available" The drive letter is F because I made a new partition for XP that is 50 GIG. the laptop has 4 gig ram. virtual memory is set to 4gig as well. I'm not sure what else I am missing but this happens for the mill, lathe and wire app. any suggestions would be great.
Something else I should add is, I had it working on an old XP machine and the machine died, Im just trying to get Mcam running again. I have the old hard drive, but I couldn't copy some of the files. maybe a certain config file will solve my issue ?
