587,686 active members*
3,709 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Solidworks CAM Post Processor for Mach 3 machines.
Results 1 to 7 of 7
    May 2008
    22
    Hello Tormach Owners,
    I have been searching for a post processor to allow me to use Solidworks CAM on my Mach 3 style PCNC 1100.
    Unfortunately I wasn't able to find anything suitable, so I have generated a version myself.
    This post is not fully tested but appears to generate code similar to that generated by Sprutcam.
    If anyone wishes to use this, please do so with caution.
    If you have any feedback I'd be happy to continue modifying the PP.
    Please note that this PP is for metric settings.
    Apr 2008
    19
    Re: Solidworks CAM Post Processor for Mach 3 machines.
    Another option is to just upgrade to Pathpilot.
    https://www.tormach.com/store/index....es&portrelay=1
    May 2008
    22
    True, but if you've got a pile of gcode files that run on the Mach 3 version, you might want the ability to continue using them, and I'm not sure whether this is the case if you upgrade to Path Pilot.
    Jun 2014
    1780
    Quote Originally Posted by JTulley View Post
    any file that runs on Mach 3 will run on Pathpilot at least in my case that was never a problem
    mike sr
    May 2008
    22
    Thanks, that's good to know.
    Quote Originally Posted by popspipes View Post
    Yep, I have files I coded years ago running Mach3 they work fine with PP when I use them now.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Apr 2020
    Good Morning, hope you can assist, I have a Mach 3 controller and Solidworks 2019, when I run the post it says its out of date, (The Licence)
    How do I go about obtaining the correct Post processor from SolidWorks 2019 to Mach 3
    Regards
    PIerre
  1. Replies: 1
    Last Post: 09-30-2020, 06:19 AM
  2. solidworks/solidcam, post processor for hass ,
    By fastcarl in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-28-2018, 09:38 AM
  3. SolidWorks post processor for Fagor 8055 T
    By Mrava in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-26-2016, 08:07 AM
  4. Mach 3 Post Processor goes where????
    By USMCCNC in forum G-Code Programing
    Last Post: 06-15-2010, 06:17 PM
  5. Mach 2 Mach 3 Post Processor
    By IntarisiaQ4 in forum Australia, New Zealand Club House
    Last Post: 10-17-2009, 11:50 PM
