587,311 active members*
3,512 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > SteelTailor Plasma Nozzle is getting damaged at the first pierce itself?
    Smile SteelTailor Plasma Nozzle is getting damaged at the first pierce itself?
    Q)The Plasma Nozzle is getting damaged atthe first pierce itself, what could be the problem?
    A) First of all check if the plasma torch has all the required pats. Check if the O-ring or the swil ring isput correctly.
    Attachment 279504
    More information about SteelTailor FAQs, Pls visit:
    Forum - Powered by Discuz!
    SteelTailor--The world leader of portable CNC cutting machine
    www.steeltailor.com
    Jan 2008
    2247
    Re: SteelTailor Plasma Nozzle is getting damaged at the first pierce itself?
    If the nozzle is getting damaged on the first pierce.....then you need to go back to the plasma cutter manufacturers operators manual and look in the mechanized cut charts. There you will find the specifications for piercing that include the recommended pierce height and the recommended pierce delay times. If your Steel Tailor machines has the ability to automatically set the pierce height and cut height....ensure that it is doing so accurately. Damaged nozzles during the pierce are caused by:
    1. Piercing too close to the material.
    2. Piercing without adequate pierce delay time.
    3. Piercing thicker than your plasma torch is designed for.
    4. Using incorrect consumables or power levels for the material and thickness being cut.
    Jim Colt Hypertherm
    Quote Originally Posted by jimcolt View Post
    Jim Colt Hypertherm
    Thank you for your kind explain. Nice day for you!
    www.steeltailor.com
  1. Replies: 0
    Last Post: 11-20-2013, 08:34 AM
  2. How to Choose Cutting Nozzle - the Component of Plasma Power
    By wisebuy 365 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-12-2013, 09:30 AM
  3. Nozzle blowing out on pierce HD4070
    By Pendu in forum Hypertherm Plasma
    Last Post: 10-23-2012, 06:10 PM
  4. PIERCE PLASMA help?
    By tibet in forum Waterjet General Topics
    Last Post: 10-07-2010, 11:49 PM
