Hello all,
the service in my area can not help with my problem, delirious filling up their pocket with money.
So I hope for help in this forum.
Maschine TM2-P
tool changer tenfold
Error description:
- tool change in program
- Machine goes to Z-position to put off the tool
- tool changer drives in from the left to the end stop
- tool is placed to the tool changer psoition perfectly
- machine activates the ventiles and gives free the tool
- lower tool- release sensor gets switched, ventiles switch perfectly
- machine moves up above the tools in Z-axis
- tool changer spinnes o the new tool (tool release is still on)
- machine goes down in z-axis do clamp the new tool (tool release is still on)
- machine stays still and waiting for clamping the new tool, but the ventil does not switch of
- 5 seconds later, red lamp and error
- 8-12sec later the tool gets clamped perfectly
- Error must be rectified manual (Recovery)
Randinfos:
Details:
- doesn’t matter witch tool place
- sensors above the spindle are working very good
- sensors are adjusted perfectly
-all axis sensors are cleaned, also the indicators
What can I do to make it work again smoothly?
It happens every or every second tool change, and we cannot work with the machine anymore.
Do we have to teach the tool exchange position?
How can we do this?
Is it possible that a ventile does not work smoothly and sticks?
The machine is working with clean and dry air.
Tnx for your help and response
Rally210er
