587,409 active members*
3,113 visitors online*
    Sep 2018
    Laser loses steps across X axis
    I have a 700x500 ebay laser / ruida controller running rdworks which is new but I can't solve an issue with the X-axis losing steps.
    I can cut a 100mm square block on the left side of the machine which measures with a digital caliber perfectly, but the same 100mm square on the right side of the bed will measure 99.5mm on x-axis. Y Axis is perfect in all corners. The machine is consistent. I can do the same cut over and over and it repeats exactly the same. Makes me assume the stepper isn't skipping.
    Things I have checked / verified:
    1) Mirrors aligned well and step length calibrate in top / left corner - machine is cutting material very well
    2) Machine is square - verified by cutting large square and checking with large square
    3) Rails are tight and very smooth - verified by removing belt and sliding head
    4) Problem is isolated to the X axis. Y axis cuts perfectly 100mm on all corners.
    5) I have replaced the X axis stepper, pulley, and driver with a 2 phase 1.2degree motor - no improvement
    6) I have replaced the X axis belt - and tried loosening and tightening
    7) I have slowed the machine way down.
    See Attached: The step loss is linear across the bed it appears. To eliminate Y axis completely and demonstrate problem, I have create dots across the x-axis every 10mm. As you can see in attached, on left side of bed 10 dots = 100.03mm. But as you move across X-axis, 10 dots becomes 99.58mm in the center of the bed and 99.34 on right side of bed.
    I'm at a loss. Anything else I should check.
    Aug 2016
    7
    Re: Laser loses steps across X axis
    That's a pretty tiny difference on a "not high end machine". It could simply be due to the geometry of the rail at that point. Check it for "perfect" straightness.
  1. stepper loses steps then stops moving all together
    By sirknight in forum Gecko Drives
    Last Post: 03-30-2014, 02:11 PM
  2. One motor from the two of them loses steps
    By Miron.Costin in forum Servo Motors / Drives
    Last Post: 10-19-2012, 09:50 PM
  3. "Y minus" loses steps on accelleration
    By Mal Buckmaster in forum DNC Problems and Solutions
    Last Post: 06-08-2009, 12:56 PM
