Okay, I've got my outlet wired up. I am using a 30 amp breaker. A black wire leads from one pole, a white from the other and of course the ground goes to ground. I am using a heavy duty 2 pole air conditioning outlet. I run the black to one pole on the outlet, the white to the other pole, and the ground obviously to ground. Or should I combine black and white to one pole and run another wire to Neutral (I don't think this is the correct way, but want to be sure)? Does any of this sound incorrect?
Now here is the real questions. I am using this outlet to run a fenner contrex m-drive to run my spindle's motor. The drive states that it can use 110-220 as input. So for my wiring, I want to run one pole of the outlet to L1, the other pole goes to Neutral/L2, and ground to ground. Does this sound correct?
