587,543 active members*
4,217 visitors online*
    Feb 2005
    7
    25 pin connector
    I'm looking for a 25 pin connector as seen in this image.
    http://www.taomc.com/bits2bots/25pin_cu.JPG
    All that I come up with in a search is standard printer connectors. I can't find one like this though. Is this something that I have to make using a printer connector and ide cable?
    24220
    That looks like a standard AMP IDC to D socket connector , e.g. amp 747306-2 the other is a standard ribbon idc header 26pin
    Al
    Aug 2004
    2849
    Go to http://www.mouser.com look for DB25 to Dual In line cables (26 pin or dual 13 position). Yes, you can also make it yourself...DB25 IDC, 0.050 spacing flat cable, and an 26 position IDC connector.
    Feb 2005
    29
    db25 d connector
    Googles earch for 'db25 d connector' turned up this as first hit also.
    http://www.talkaboutelectronicequipm...es/146130.html
    FWIW
    DaveP
    24220
    Except that refers to a wired 25pin D as compared to the ribbon version in the first post.
    Al
  1. Staggering motors
    By viktorcnc in forum Stepper Motors / Drives
    Last Post: 10-25-2015, 08:11 PM
  2. Sourcing Hardware (1/8 Pin with threads)
    By Swami in forum MetalWork Discussion
    Last Post: 03-26-2005, 05:35 PM
  3. Help find terminal connector type for this stepper
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 10-09-2004, 07:34 PM
  4. DB25I/O and software
    By pminmo in forum CNC Machine Related Electronics
    Last Post: 08-13-2004, 02:27 PM
  5. Pc Rs232 > Fanic 10te-f
    By abselect in forum CNC Machine Related Electronics
    Last Post: 07-06-2004, 03:23 PM
