587,827 active members*
2,882 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Mitsubishi AC servo motor 9 pin encoder connectors... Where to buy them?
Results 1 to 7 of 7
    Oct 2006
    84
    Have a few motors with cut wires and am looking for the 9 pin, square encoder connectors for motors in the HC-MFS43 family of ac servo motors.
    The connectors say "AMP" on them, but haven't been able to find them online after various searches. Doesn't appear molex has a matching connector either.
    24220
    Re: Mitsubishi AC servo motor 9 pin encoder connectors... Where to buy them?
    If they are amp, there is usually a number on them somewhere?
    Al.
    Oct 2006
    84
    dont see one...
    24220
    Have you tried removing the shell cover to see if it reveals anything?
    Phone Mitsubishi parts in Ill they should help.
    Al.
    Jan 2011
    350
    HC cable document:
    temp pdf
    Cheers.
    Oct 2006
    84
    Think I found 'em
    Service Unavailable
    minimum order 2800
    Jan 2011
    350
  1. Mitsubishi AC servo encoder outputs?
    By Tristar500 in forum Servo Motors / Drives
    Last Post: 04-13-2012, 08:15 PM
  2. Mitsubishi servo motor HA80C-S
    By keyancnc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-05-2011, 07:47 PM
  3. Mitsubishi dc servo motor
    By jolulank in forum Servo Motors / Drives
    Last Post: 02-18-2011, 02:32 AM
  4. Need Mitsubishi Servo Motor
    By macona in forum Want To Buy...Need help!
    Last Post: 11-13-2010, 09:32 AM
  5. Wiring for Mitsubishi AC Servo HA-FF Encoder
    By kumphanart in forum Servo Motors / Drives
    Last Post: 08-24-2008, 07:30 PM
