Still having problems with my Superior Electric Slo-Syn ss2000D6 drive.
I have the 5v from my usb connected to the Opto input, where it is supposed to be. I have the correct pins from my parallel wired to my Pulse/Step and Direction inputs.
My problem is that my motor only turns clockwise.
The manual states that the motor will turn clockwise when the Direction signal is High.
If I short the Direction input to ground or just unplug it the motor reverses direction and runs counterclockwise because the signal is no longer High and is now zero. This seems to indicate that the drive is not recognizing the Low state.
The manual says that the Direction input should be Low if it is <= 0.8Vdc and >= 0.0Vdc
I measured it when I pushed the keypad on the computer and it measured .08Vdc....which is on the low side of the range but still within parameters.
The manual says the the Direction input should be High if it is <= the OPTO and >= OPTO-1
My OPTO measured at 4.9 volts.
When I pressed the keypad to go in the High direction the DIR input measured 3.5 volts which is not >= OPTO-1 (4.9-1=3.9) So it seems to be out of spec.
The strange part is that the High signal is what seems to be working because the high signal is what moves the motor in the clockwise direction (which is what I am getting) but the High signal is the one that seems to be out of the acceptable parameters. The Low signal moves it counterclockwise and that is the direction I am not getting even though those readings are within spec.
Anyone else had problems with a motor only turning one way? Am I even barking up the right tree here? The pulse/step is working just fine but I don't understand why the direction is not working. The voltage readings and wiring scheme is identical on my Gecko drives and it works just fine but with these Superior Electric drives my Dir signal doesn't seem to be working. Any suggestions?
