587,175 active members*
3,035 visitors online*
Thread: Tornado 100
    Tornado 100
    Hi
    I have a tornado lathe 100. I have alaram
    1018 turret is too slow.
    Any body can help me?
    Re: Tornado 100
    Quote Originally Posted by Engnabild View Post
    Hi
    This alarm means the tool change time takes too long.
    1- Check if the turret has problem or not, if there is then fix it.
    2- If the turret has no problem, you can set parameter on the CNC controller to make the tool change time longer.
    Dec 2015
    41
    Re: Tornado 100
    Hello I am having the same error message on my lathe. Which parameter needs to be changed for the turret time functions?
  1. Tornado 100 Spindle Lubrication
    By zoeper in forum Colchester Tornado lathes
    Last Post: 02-05-2015, 06:43 PM
  2. Colchester Tornado 100 Specs
    Last Post: 11-24-2014, 10:38 AM
  3. Tapping on Tornado 100
    By Clive Dunn in forum Colchester Tornado lathes
    Last Post: 05-21-2014, 10:24 AM
  4. Colchester Tornado 100 Fanuc OT
    Last Post: 05-23-2013, 08:05 AM
  5. tornado 100
    By cgjohn in forum Colchester Tornado lathes
    Last Post: 12-23-2008, 02:10 AM
