Ok, I so suck at math. I am setting up mach3. I am trying to figure out what microstep I should be running, acceleration curve, tpi, ect. I been looking at the formulas but I seem to be getting lost. Part of it is I don't know the max rpm of my steppers. I will give you as much info as I can. Any help would be great.
I am running a Joes's 2008 r-2
x-y screws are 1/2" - 5 start - 2 tpi
z screw is 1/2" - 2 start - 5 tpi
My steppers are Keling 425oz-in unipolor motor 8 lead wired in bipolar parallel
1.8degree / 2.8A / 6.8 inductance
I have Keling 4030 drivers
So I will only sending 2.7A @ 36v to the motor. My power supply will go up to 40v but that is the max that the 4030 can take and I was worried about back emf so I left it at 36v.
What microstep should I run at? 1/8th, 1/4th on x&y? What on the z?
What is the max rpm of my stepper? I am not sure about how many steps per inch. (motor steps x tpi x micro) (200 x 2 x 8)= 3600 steps per inch @ 1/8 microstep?
What Frequency should I run at. My cnc pc is pretty decent but I know it is related to the steps per minute.
What acceleration curve should I use? IE ramp up/down time. What should my acc curve be once I make stepper dampers? I know you have to allow a little more time but how much?
Will I have rapids of 120-150 ipm?
I am just trying to put in the necessary info into mach3
