587,466 active members*
3,234 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > New easy to use 2.5D and 3D CAM Programs
    Post New easy to use 2.5D and 3D CAM Programs
    Hello,
    during the last 1-2 years I've programmed 2 CAM programs for 2,5D and 3D milling. They are (hopefully) very easy to use and intended for hobbyists and small business.
    You can download the software at www.estlcam.com
    The first one is Estlcam 2,5D:
    • It works with .dxf drawings
    • Besides "normal" milling it can also create pockets and works with different depth levels.
    The second one is Estlcam 3D:
    • It works with STL models
    • It is very simple - you basically just define your tools and decide which machining direction you prefer
    I've just finished translation from German to English a few days ago - hopefully the translation is not too bad and everything works well (I'd be glad if someone tells me if I use wrong or unusual descriptions - I've also experienced some troubles caused by the English decimal point crashing the program in the past but I hope this issue is fixed now)
    Kind regards
    Christian Knüll
    Mar 2010
    6
    Not working with me
    Dear Christian,
    I just installed the software. I am using Windows 7 with .net installed.
    I see the grid before I open a file and see a blank screen with a cross-hair only. I can draw lines with your software but the file open does not seem to work.
    Hello,
    can you send me your file so I can see what is going wrong?
    (my email adress is: [email protected] )
    thank you!
    Christian
  1. easy to use cad programs
    By speed seeker in forum Australia, New Zealand Club House
    Last Post: 08-24-2008, 03:38 PM
  2. Probably an easy one: CAM programs and NURBS
    By Hirudin in forum Uncategorised CAM Discussion
    Last Post: 08-07-2008, 03:36 AM
  3. MastercamX not so easy with easy projects
    By X7racer in forum Mastercam
    Last Post: 05-22-2008, 03:28 AM
  4. easy for some,
    By skydivebase in forum OneCNC
    Last Post: 05-27-2007, 02:36 PM
  5. Easy CNC and Easy Stepp'n
    By kylecroft in forum Community Club House
    Last Post: 02-18-2007, 06:54 PM
