Is there a way to tell NCPlot when it starts what machine configuration to use?
I have gcode for both mills and lathes - so when I invoke NCPlot programatically, and pass the gcode file name to open as part of the command line, NC plot does not know (50% of the time) how to interpret the loaded gcode... I'm getting tired of having to manually change the machine config after ncplot loads
What I think I'd like is a way to tell NCPLot the machine config to use via a command line switch. Then when loading mill gcode I'd tell it to use the mill config, when loading lathe gcode, I'd tell it to load the lathe machine config.
Or maybe there is another way to solve this?
Dave
