587,098 active members*
6,325 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Fanuc Compact flash pc editing tool for large programs
Page 1 of 3 123
Results 1 to 20 of 41
    Apr 2018
    23
    Question Fanuc Compact flash pc editing tool for large programs
    Hello,
    I am able to create large files and save them to a compact flash card using the PC editing tool from Fanuc which saves programs to a bin. file on the card.
    Operation is identical to machine memory when running at the control other than all of the probing macros etc. being in the machine memory side so you have to switch back and forth to probe. (I wonder if you could copy the machine 900 programs to the bin file to workaround this?)
    But my problem is I can not view these programs inside the bin file back at my PC. The PC editing tool that puts the programs onto the flash card is a one way ticket, I can go to the machine no problem, but if I make edits to the program on the control I can't get back to my PC to continue working with the program.
    This bin file needs some sort of read software that can open the individual files on the compact flash card so I can add to the program/alter without having to start back at the original file that was drug onto the card.
    HELP ME PLEASE!
    Mar 2017
    314
    Re: Fanuc Compact flash pc editing tool for large programs
    why dont you leave it as a regular .txt type file and dnc from the card?
    May 2016
    526
    Id agree with Disarray you're making it far to complicated
    If its its already in cnc memory output it as a text then you can open and edit it in any package
    Dec 2012
    395
    Program is not stored in memory but only on PCMCIA-card, on my 0i-MF it doesn't work from USB.
    When you make changes on the machine you can read the BIN-file back on PC.
    Open the FANUCPRG.BIN on your PC from card, then you can see the programs in the BIN-file.
    Drag and drop them on your desktopscreen or in a folder and you can open them.
    Heavy_Metal.
    Attached Thumbnails Attached Thumbnails Fanuc-Program-Tool-v5.JPG   Fanuc-Program-Tool-v5.JPG
    Apr 2018
    23
    Quote Originally Posted by Heavy_Metal View Post
    Heavy_Metal.
    When I open the BIN file at my pc it wont let me drag the files onto my desktop. I can drag onto the compact flash, cant drag off.
    Apr 2018
    23
    Quote Originally Posted by mbservice View Post
    Compact flash memory is only stored on the card, it's fanucs way of working around having no memory. You cant output files from flash card memory.
    Apr 2018
    23
    If I try to drag the files into an empty folder this happens
    Dec 2012
    395
    Hi Machinistsss,
    Upload your FANUCPRG.BIN file then I will try to "unlock" it for you or send me your e-mail by private message.
    Heavy_Metal.
    Apr 2018
    23
    Thank you for the offer, but I can't send all my programs to a stranger. I know the card is formatted correctly and it runs fine on the machine. Any idea why it won't let me drag back to the desktop?
    Dec 2012
    395
    Hi Machinistsss,
    OK, I understand that.
    Try it with my test FANUCPRG.BIN file, it contains 2 Cimco-Edit sample files.
    I can't upload BIN-files so I put it into a zip-file.
    Or make a simple BIN-file for me to try and upload it.
    Heavy_Metal.
    Apr 2018
    23
    Here is a test file for you to try out, I can't get even this small file to go back to desktop.
    Thanks for your help
    Dec 2012
    395
    Hi Machinistsss,
    You send a O0001 file but not a FANUCPRG.BIN file.
    When I open the O0001 file with WordPad it results in:
    O0001
    (TEST OF MEMORY CARD FUNCTIONALITY)
    G0 X6. Y6. Z6.
    (END OF TEST)
    I need a FANUCPRG.BIN-file from you to try with the --- FANUC Memory Program Tool !!!
    Heavy_Metal.
    Apr 2018
    23
    Sorry about that lets see if this works.
    Dec 2012
    395
    Hi Machinistsss,
    It works, did you open your own file with the Program Tool ??
    Look at the attachment.
    Heavy_Metal.
    Attached Thumbnails Attached Thumbnails Fanuc-Program-Tool-v5-#1.JPG   Fanuc-Program-Tool-v5-#1.JPG
    Apr 2018
    23
    Hi Machinistsss,
    Heavy_Metal.
    Maybe my PC editing CD is messed up, I can't get it to drag to desktop. I was 99.9% sure I was doing everything right. I guess I'm going to have to wait for fanuc to reply with a fix. Fingers crossed.
    Dec 2012
    395
    Hi Machinistsss,
    Do you start/run the Fanuc Program Tool from CD or from PC ???
    The CD contains only 3 files:
    2 pdf manuals (400kb), English and I think Chinese
    1 EXE.file, FANUCPRG.exe (600kb)
    Check your private message !
    Heavy_Metal.
    Dec 2018
    Hi, can you send me FANUCPRG.exe please?
    thx
    Apr 2013
    13
    del///
    Apr 2013
    13
    Heavy_Metal.
    It works with only CF cards?
    You tried it on 0MD or 0MC ?
    Dec 2012
    395
    Yep, it works only on CF-Card (PCMCIA-slot).
    We have a FANUC 0i-MF but it works also on the 0i-MD, maybe also on the 0i-MC, not the 0-Model C or 0-Model D.
    What control do you have.
    Heavy_Metal.
Page 1 of 3 123
  1. Replies: 11
    Last Post: 05-04-2021, 06:02 PM
  2. Fanuc Compact flash/PCMCIA HELP!
    By DeXtrous in forum Fanuc
    Last Post: 07-17-2016, 04:46 AM
  3. Replies: 2
    Last Post: 02-11-2016, 05:50 PM
  4. Fanuc Compact Flash to USB
    By Coyote553 in forum Daewoo/Doosan
    Last Post: 07-22-2011, 02:21 PM
