587,173 active members*
3,732 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Newbie that need help with first time servo motor set up
    Hi people ,
    I bought the Kflop and Kanalog to retrofit my CNC biesse rover 346 with analogue servo motor on it...I have install the Kmotion and Kflop software, everything seem nice, The first ten minutes was wonderful, the servo was moving forward and backward ,
    I have connect the 4 wires encoders to J1 and the 1,2,3,4 and torque cmd -10v +10v(daco) to JP11 1 and torque cmd common to JP11 9...
    but now nothing move !
    Did I change or touch something wrong in other page option, the servo motor are Delta SGDG 400watt drive legend 04
    May 2006
    4047
    Re: Newbie that need help with first time servo motor set up
    Hi Fabinmotion,
    The first step with any servo system is to verify that you have things wired correctly and that each hardware component functions. In your system you have encoder feedback and a DAC to apply motor drive. Have you verified each is working properly? You might read this Thread:
    http://www.cnczone.com/forums/dynomo...ml#post1457094
    A common problem is that a User will configure an Axis to drive Step/Dir Outputs on KFLOP JP7. JP7 is used for communication to Kanalog and you should not do this. If you do this communication with Kanalog will be lost and the loss of communication with Kanalog will caue the Enable LED on Kanalog to go out. Are you doing this?
    Regards
    TK
    http://dynomotion.com
    24223
    What does the 7 segment indicator show?
    Al.
    I need someone to connect via team viewer and go step by step, you have offer me that Tom last year, I have 3 cnc in my shop that I want to upgrade with this systems, So I am looking for a learning cession ...I know life cost money, I know, But I need to get the Biesse cnc moving ...anyone is available for a 2 hours ....next week, I will prepare everything ...Erik
    May 2006
    4047
    Hi Fabinmotion,
    Sorry to hear you are still struggling. Contact Dynomotion Support and provide an email we can send an invoice for personal support.
    If you could describe the steps you are doing and what happens we should be able to help here on-line.
    Regards
    TK
  1. Axis servo motor vs. Spindle servo motor
    By iyerks in forum Servo Motors / Drives
    Last Post: 09-25-2012, 04:58 PM
  2. Newbie Identifying Servo Motor
    By Rencio7 in forum Servo Motors / Drives
    Last Post: 10-25-2011, 09:42 PM
  3. Newbie- Servo motor torque question
    By byrdman73 in forum Servo Motors / Drives
    Last Post: 06-10-2009, 12:41 AM
  4. big time newbie
    By 72k5 in forum Okuma
    Last Post: 04-15-2008, 06:41 PM
  5. Newbie: is there difference between stepper and servo motor?
    By g888h in forum Stepper Motors / Drives
    Last Post: 09-11-2006, 01:50 AM
