587,896 active members*
3,471 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo PUMA-6J Lathe Help
    Mar 2021
    Question Daewoo PUMA-6J Lathe Help
    hello!
    i need help PUMA 6J Machine Parameter Power Off after Clear
    controller Fanuc 0-T Series
    Machine made in 1994
    x,z Axis Servo motor α3/3000
    Spindle Servo motor α6/speed unknown
    All Clear Parameter & DGNOS Data
    Help me Please.
    Mar 2021
    22
    Re: Daewoo PUMA-6J Lathe Help
    Quote Originally Posted by Maintenance-Man View Post
    hello!
    Help me Please.
    Hi maintenance-man I have a daewoo puma 8hc with the same problem as yours, it lost the parameters and I am still looking for the appropriate parameters since on the internet I have been able to get some of the daewoo puma but not the exact mine that is if you want I can share you I have the case that my machine has managed to make the hydraulic and lubricant work but not the axes and the spindle is the machine with an interlock of not ready and two relays of LEDs in the cabin lit hovl and movl, you can send me photos of your puma 6J to see how similar it is to mine? If it is similar to mine, do you have the user manual?
    Feb 2013
    788
    There is a set of parameters of how the machine left Korea, located in the pocket welded into the inside of the electrical cabinet door,
    Here is a generic set. It is likely that they will not completely recover the machine, as they are serial number specific.
    To anyone who has a machine YOU CAN MAKE YOUR OWN BACKUP at ANYTIME YOU WANT!
    You can backup the full readable files, as well as a binary copy of SRAM.
    This backup can be done in about a minute.
    If there is a functioning machine on your shop floor...GO...DO A BACKUP...Today.
    Then you won't have these issues.
    Attached Thumbnails Attached Thumbnails P6 0T parameters.pdf
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2013
    788
    If your 8HC has a 15T control, here is a generic set. (it is likely that it will not fix all issues as many parameters are serial number specific)
