587,436 active members*
3,649 visitors online*
    May 2006
    202
    Question Which Hydraulic Oil do I use?????
    To All (Newbie) no machine manual! I had to disconnect the hydraulic lines to remove my spindle motor and I'm trying to bleed the line, but out of hydraulic oil. What type do I need to use or will any hydraulic oil do??
    Thanks for your assistance
    Ben
    24223
    I have been told in the past that it is not so much what you use but the viscosity should match the application/temp range, there are Hydraulic supply reps. in most large towns, maybe look thorough the phone book for a local one to advise you over the phone.
    Al.
    May 2006
    202
    Smile Hydrualic Oil
    Got it guys and thanks.
    Ben
  1. hydraulic chuck
    By Runner4404spd in forum Mini Lathe
    Last Post: 02-11-2007, 11:46 PM
  2. Hydraulic pump and motor?
    By DennisCNC in forum Mechanical Calculations/Engineering Design
    Last Post: 07-28-2006, 06:30 PM
  3. HELP - How to service a hydraulic vice.
    By Chad Cappa in forum MetalWork Discussion
    Last Post: 11-20-2005, 04:12 PM
  4. Where to buy Rexroth Hydraulic valve?
    By mjse in forum Community Club House
    Last Post: 07-23-2004, 01:28 PM
