587,168 active members*
3,353 visitors online*
Results 1 to 7 of 7
    Mar 2008
    377
    how to set a touch screen on the screen of mach 3
    hello i seen people do the touch screen on the computer.
    does someone know how to do this if so can you tell me how to go about it.
    thanks
    Feb 2007
    4553
    Smile Touch Screen Kit
    See attached link for kit.
    http://tinyurl.com/5ko8ur
    Jeff...
    Basically the touch screen just replaces the mouse. It has nothing to do with the software you're running. Once the screen is working, you just use your finger instead of the mouse.
    You can either buy an add-on touch screen, or an actual touch screen monitor.
    http://cgi.ebay.com/NEW-17-TFT-POS-T...3286.m14.l1318
    http://cgi.ebay.com/Elo-LCD-Touchscr...3286.m14.l1318
    24223
    Another couple of things to watch for if adding on, there is one type for CRT (curved) and flat for LCD.
    Also controllers can be RS232 serial port or USB.
    Al.
    Mar 2008
    377
    Quote Originally Posted by jalessi View Post
    Jeff...
    thanks for the quick answers to all I really appreciated.
    So basically I would just buy this plastic thing put it over my monitor and by the way it looks just load the software and that woud convert it to a touch screen. is that how it works.
    thanks again
    :cheers::cheers::cheers:
    Feb 2007
    4553
    Smile
    Yes,
    Basically it is that easy.
    There are also several aftermarket user developed Mach3 front ends that have bigger buttons "icons" for touch screen adaptations.
    Jeff...
    Jeff...
    My new one should be pretty touch screen friendly.
    http://www.cnczone.com/forums/showthread.php?t=61101
  1. Acromatic 950 Touch Screen Retrofit - No Response From Touch Screen
    By csokoll in forum Controller & Computer Solutions
    Last Post: 05-27-2014, 09:41 PM
  2. Mach 3 & touch screen
    By jepetera in forum Videos
    Last Post: 09-11-2011, 06:16 PM
  3. New Screen set for my touch screen
    By Scott_M in forum Tormach Personal CNC Mill
    Last Post: 08-17-2010, 01:37 PM
  4. touch screen
    By swarfmacdaddy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-03-2007, 04:59 PM
  5. anyone use a touch screen?
    By jderou in forum Screen Layouts, Post Processors & Misc
    Last Post: 09-02-2005, 12:09 AM
