587,651 active members*
3,611 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Are there 3D models of Novakon machines available?
Page 1 of 4 123
Results 1 to 20 of 64
    Jun 2008
    1082
    I've drawn up a very basic model of my Torus Pro. It's getting the job done for what I want, but I wish it were more complete. Is there a model of the Torus Pro available for download from somewhere? Novakon, since I know you monitor this forum I have a question: would you have any issue with someone posting their self-made model so others could download it?
    Mar 2011
    480
    A model of the Torus Pro would be great. HSMworks can do machine simulation if i can get my hands on a solid model. Don't really have the time to reverse engineer the major mill components yet.
    Aug 2008
    400
    To see a facsimile posted would not be a problem for us. There are slight variations of this series of mill, but for the purpose stated, it would be a great idea as Lakesnake stated.
    It would be interesting to see!
    Novakon Team
    Jun 2008
    1082
    Whelp, I've been working on making a model today. I think it's looking pretty good so far.
    Would anyone like to help with this project? I'll attach a picture of everything I've drawn up so far. The major parts that still need to be done are the column (is that what it's called?), base, and saddle. The stand, chip trays, computer box, and motors could be handy as well.
    Mar 2011
    480
    Hirudin,
    That's looking good. What format/CAD are you using ?. I would be willing to help/add on to what you've done so far.
    Matt
    Jun 2008
    1082
    Thanks!
    I made everything in SolidWorks. I modeled all the pieces as separate 'part' files and have brought them all together as an 'assembly'. I drew up the base, both main pieces of the column, and am about to do the saddle. I couldn't (read: didn't feel like taking the time to) measure these pieces as thoroughly as some of the others, but I think they're pretty close.
    Here they are...
    Index of /forums/cnczone/toruspromodel
    Attached Thumbnails Attached Thumbnails Torus Pro 3D model 02.jpg   Torus Pro 3D model 03.png
    Jun 2004
    6618
    Just a question for you.
    Does Solidworks have perspective view?
    Since it is only a rendering here, I think it looks better when viewed with perspective. That is the art training in me I think.
    It just looks wonky to me.
    Nice work though.
    I can see where this would be a benefit for several things. Enclosure, pdb, atc and even some tooling plates could be designed with the help of a drawing like this.
    Here is an image of my plasma cutter done with perspective view turned on in Turbocad.
    Lee
    Quote Originally Posted by LeeWay View Post
    Nice work though.
    Solidworks does have prospective view for things like renders. It has a bunch of built in materials that can apply styling and texture. We generally run with textures turned off, but they are easy to work with and yield some high quality results.
    Fine Line Automation
    www.finelineautomation.com
    Jun 2008
    1082
    (I uploaded the files - link above.)
    I like to work with perspective turned off, so usually don't remember to turn it back on when I'm taking a screenshot*. I also usually don't bother to put textures on my models, but I also wasn't aware that it was possible to turn them off.
    * The SolidWorks that I own doesn't seem to have a "render" command as far as I can find so I just take a screenshot. I also can't seem to make antialiasing work. I'm assuming my graphics card drivers are messed up somehow.
    Jun 2004
    6618
    Can you save them in something other than a Solidworks file?
    I can open a lot of different file types, but that ain't one of em.
    Maybe DXF.
    Lee
    Jun 2008
    1082
    Exporting to DXF is always a pain. How about IGS files. Can you open those?
    I tested the "Head shroud 01.IGS" file with Rhino (v. 4) and it opened nearly perfectly. All the curved surfaces look nice and the dimensions seem to be correct. The only problems were that all the surfaces were separated (select all > join fixed that) and it opened in an odd orientation (a quick rotate fixed that).
    Jun 2004
    6618
    I can open that type fine in Turbocad.
    I do notice when I am working on a drawing in Turbocad and expect to produce nice renders later, I have to save the file in a Turbocad format.
    When I save in dxf, it looses all the materials, colors, lighting etc that I have used. Turbcad files will keep every bit of the data as it was before you closed the file.
    I imagine solid works would be the same.
    Lee
    Jun 2008
    1082
    Yeah, it seems like most programs will only play nicely with their own file type. Rhino might be a slight exception. The native SolidWorks file type has the added bonus that it shows the construction history and since it's a parametric modeler you can also go in and change the dimensions easily. It's very cool! I haven't used Alibre, but I imagine it's the same way. Another cool thing is the assembled file, "Torus Pro 01.SLDASM", is put together in such a way so that you can actually "grab" the head or the bed and move it around - I've set it up so the movements are restrained to the mechanical limits of my actual machine.
    Jul 2006
    525
    Grabbed the models, maybe they'll come in handy some day. Looks good at a glance, came into SW and rebuilds with no errors
    Jun 2004
    6618
    The IGS file opens great in Turbocad. I don't have the Pro, but I still like the drawing.
    Lee
    The solidworks parts import fine into alibre, this will make a nice addition to my 3D printed 1/4 scale model collection, thanks for sharing.
    Hoss
    Jun 2008
    1082
    You're welcome. Wow, those are way cool! I imagine the model is good enough for your purpose, but since I had to basically guess with some of the dimensions you might want to hold off on printing for a little while. For instance: I didn't have a way to measure the depth of the column at the very top (it's covered). I also didn't even try to get the rear of the base or column to be correct.
    It'll never be perfect though, so whenever you do end up printing it will you post a link to the video in this thread?
    Jun 2004
    6618
    Wow Hoss. I hadn't seen those, but googled em.
    Post 1390 in this thread.
    http://www.cnczone.com/forums/commer...inters-35.html
    Do you have a better thread for it? Very cool stuff.
    I'd like to go a step further some day and make then functional.
    Lee
    The g0704 was the first model, i put more detail in it since I used my real part models too.
    G0704 Quarter Scale Model Stand and TTS - YouTube
    The rest were mainly to show for scale comparison so the torus pro will be great for that.
    Most of them the table, saddle and head move, some the head tilts too, I'll mod the parts for this as well to get the same thing.
    I'll post the video here too as I'm sure the size comparison will be interesting, I'm looking forward to it also.
    The Torus Pro would be my choice if I didn't have space and physical disability issues.
    I'll keep an eye here for any updates before printing.
    Hoss
    Hirudin, I have your models redone to printer friendly versions, scaled to 25% and sliced (made g-code).
    Will take a total of 53 hours to print and use about .77 kg of filament, only about $20 worth.
    Probably be a week till it's finished as time allows.
    The table will move and the head will tilt but the z slide looks missing and no dovetails on the column but I can just glue the head in place.
    Later Hoss
Page 1 of 4 123
  1. Novakon nm-145
    By patycoop in forum Novakon
    Last Post: 09-15-2015, 12:33 PM
  2. First cut with my new to me Novakon nm 200
    By ram48 in forum Novakon
    Last Post: 06-03-2013, 08:13 PM
  3. Novakon going under??????
    By metalgearz in forum Novakon
    Last Post: 12-12-2011, 03:29 PM
  4. Solid Models of Machines?
    By behindpropeller in forum Haas Mills
    Last Post: 10-20-2011, 06:45 PM
  5. Novakon Machines in the UK
    By antsals in forum Novakon
    Last Post: 07-06-2010, 12:41 PM
