587,202 active members*
2,958 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > Employment Opportunity > RFQ - Lathe Work 5 different prints. 2000 - 2800 pieces total
Results 1 to 1 of 1
    Aug 2010
    I need a quote on the attached files.
    I would like the '1 inch spud' and the '4.5 inch grip extension' manufactured at the same shop so they have the same finish.
    I would like the 'handle clamp 2' and the 'handle rod' manufactured at the same shop since both parts need to thread together.
    Along with your quote I would like to know turn around time if you are awarded the job.
    Please do not try to figure shipping costs in the quote. Lets keep it simple and I will pay for the shipping costs when the job is done.
    I am hoping to have these in 2-3 weeks without having to pay extra for a rush job. If you have some openings I have some work for you.
    Here are some more specifics on each item:
    1) 1 inch spud
    6061 aluminum
    32 finish
    Quote for 200, 300 and 400 pieces
    2) 4.5 inch grip extension
    6061 aluminum
    32 finish
    Quote for 100, 200 and 300 pieces
    3) handle clamp 2
    6061 aluminum
    63 finish
    4) handle rod
    6061 aluminum
    Extruded finish if fine as long as there ar no dings. If you want toturn it down from 1" material then a 125 finish is fine
    5) button machine
    White Delrin
    The top dome is cosmetic and must have a good finish.
    Quote for 1500 pieces
    Please email me all quotes and questions. If you have some immediate questions you can leave oyour phone number and I will call you.
    [email protected]
    thanks,
    Walt
    Attached Files Attached Files
  1. Completed Work Pieces
    By joecnc2006 in forum Joes CNC Model 2006
    Last Post: 07-05-2012, 04:44 AM
  2. RFQ - Lathe Work 300-500 pieces 6061 Aluminum
    By jpmf1001 in forum Employment Opportunity
    Last Post: 01-19-2011, 06:48 PM
  3. Lathe Work for 20 pieces
    By stang5197 in forum Employment Opportunity
    Last Post: 09-27-2006, 04:10 AM
  4. Milling work to square up pieces
    By mrbaseball in forum Employment Opportunity
    Last Post: 01-23-2006, 08:07 PM
  5. *WORK ASSIGNED* RFQ - 2 pieces CNC'd aluminum emblem
    By dallas4u in forum Employment Opportunity
    Last Post: 01-14-2006, 02:41 AM
