587,089 active members*
3,020 visitors online*
    Sep 2013
    Epoxy granite vertical mill cnc
    Few years ago I decided to build a cnc milling machine and today it's almost done. It took a long time to decide what to build. here is the result:
    I had no access to milling machine so the only way for me was to use epoxy granite structure, because the mold can be done using wood from local supplier. unfortunately I loos the picture from the mold. I only have a picture of a test mold that I did before the real one:
    Attachment 382798
    Next pic is the assembling of the horizontal base and the column:
    Attachment 382800
    Assembled with linear rails and ball screws:
    Attachment 382802
    The first version of the table:
    Attachment 382804
    Allining the square on the Y:
    Attachment 382806
    and then the X on the square (and of course the Y):
    Attachment 382808
    First fully assembled:
    Attachment 382810
    With this configuration I did some very preliminary test:
    https://www.youtube.com/edit?o=U&video_id=UJpgwJOtuAw
    And I also tryed to mill the table:
    https://www.youtube.com/edit?o=U&video_id=0Hq5-3X2nuc
    Conclusion was that the temporay spindle headstock is very bad so next step was to upgrade it:
    https://www.youtube.com/edit?o=U&video_id=hUZ-PSfBLuI
    But it didn't turn very well and the table assembly which was not as strong as I thought, then I decided to upgrade it also:
    Laser cutted steel parts:
    Attachment 382812
    To be continued...
    Sep 2013
    Re: Epoxy granite vertical mill cnc
    The parts assembled:
    Attachment 382814
    Stick weldeed:
    Attachment 382816
    And after some filling and scrapping of the surface, some painting, being assebled:
    Attachment 382818
    Allining again X and Y:
    Attachment 382820
    tramming the spindle:
    Attachment 382822
    Here the video of the tramming:
    https://www.youtube.com/edit?o=U&video_id=FOWqXXOsYV4
    Full view of the machine:
    Attachment 382824
    Same with the vise, soft jaws has been milling on this cnc:
    Attachment 382826
    I hope you enjoy this build, comments and questions are welcome.
    Bzaz.
  1. Large Epoxy Granite Vertical CNC Mill
    By petruscad in forum Vertical Mill, Lathe Project Log
    Last Post: 10-08-2022, 10:45 PM
  2. Mark's EPOXY Granite 18"x20"x20" (700mmx780mmx780mm) vertical mill build
    By gt40 in forum Vertical Mill, Lathe Project Log
    Last Post: 01-19-2019, 09:26 PM
  3. Epoxy granite CNC mill inspiration
    By IIIDMeister in forum Epoxy Granite
    Last Post: 02-16-2017, 07:48 PM
  4. Epoxy Granite Mill Head filling
    By d@niel in forum Epoxy Granite
    Last Post: 06-23-2015, 02:49 AM
  5. Epoxy Granite enhanced LMS SX2 CNC mill
    By SwampDonkey in forum Benchtop Machines
    Last Post: 05-01-2012, 07:05 PM
