587,395 active members*
3,851 visitors online*
    Trumpf punch with Bosch controller
    Hello all,
    I have a problem with a Trumpf Trumatic 200 from 1994. The machine has sat for over a year and now after turning on I replaced de batteries , one 4.5 v for the RAM and the other 3.6v in the power supply. The problem is that the error CP/MEM-BATTERIE dosen t go away and also NC FAult 2685 witch has something to do with linktables. If the machine sits for a couple of hours turned off then at start up it requests to reload the machine program procedure: Aus Eprom ..., Password.
    I have no real experience with this controller , any advice will be appreciated .
    Nov 2021
    12
    Re: Trumpf punch with Bosch controller
    the machine has at least three batteries, did you replaced them all?
    Jan 2024
    Hi there
    We have a Trumpf 500 however we have a fault come up saying no fault 2685
    Cp men battery low but these have been changed
    Where is the third battery on this machine as we have only found 2
    Any help would be highly appreciated
    Cheers
    Joe
    Attached Thumbnails Attached Thumbnails B79625EA-D6DD-4805-BE6D-2DE392C77E37.jpg   D6989102-07A8-4081-A958-1BC66DB1D393.jpg
  1. Trumpf Trumatic 3000 punch laser programming help
    By Essix in forum Uncategorised MetalWorking Machines
    Last Post: 12-22-2016, 11:23 PM
  2. G-code for Trumpf turret punch
    By Sparkman Stan in forum G-Code Programing
    Last Post: 02-27-2016, 06:29 AM
  3. Trumpf L3030 Bosch c220s Controller
    By ettienem in forum South Africa Club House
    Last Post: 02-27-2013, 09:40 AM
