587,518 active members*
3,420 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Moving a Prototrak mill under a garage door opening
Results 1 to 13 of 13
    Sep 2007
    7
    I have a 1997 model SWI Trak DPM coming in a few days and want to put it in my garage. The garage door opening is standard 84 inch high. The mill's column is 85 inches high, based on SWI spec sheet. I was told by a guy who once had one of these that he put it in his garage by removing the column cover and then sliding the mill on a piece of sheet steel. Anyone have any experience with this? Any photos or advice? Thanks in advance.
    Oct 2006
    73
    HI kentucker,
    I have a Mid 90's DPM myself. The suggestion sounds reasonable, however, I have never had my column cover off so I don't know how much extra clearance you will gain. Sheet steel will work very well as a sled but plywood might do in a pinch. Steel is pretty expensive.
    I'm sure you thought of this already, but the biggest problem you will face after you get the clearance issue resolved is how are you going to drag that machine across the floor. I don't know if your garage is big enough to tow it in with a vehicle. You may want to drag it in with a come-along and some chain. The machine is not so heavy that you couldn't inch it in with a good pry bar.
    How are you planning to unload the machine from the truck?
    Hope this helps.
    How much time time do you have before it arrives? I think Saturday afternoon I could pull the cover off of mine and find out how much room you will get.
    Sep 2007
    7
    Hi Bishb,
    I would greatly appreciate having a look inside your machine if it isn’t a huge hassle. It will give me a heads up as to what I face.
    I think I’ll have it moved by a machinery mover recommended by the above mentioned former DPM owner. I just don’t want to take a chance of damaging a nearly $20k machine.
    My garage has a 9 foot high ceiling, so once in, clearance is not an issue. I’m taking up half of my 2 car garage, and the car in the other half is in jeopardy of losing its place to make room for more machinery. One must have priorities straight.
    I went to the SWI website and downloaded the user’s manual for the old Trak series machines. If you didn’t get the manual with yours, you should get this. It is about 23 MB, and well worth the download time.
    http://www.southwesternindustries.co...941_manual.pdf
    Anticipated arrival date is Feb 19-20.
    Thanks for your input.
    Oct 2006
    73
    Yeah, I have the manuals. I also have a great team at my local ProtoTrak distributor, http://starlitegroup.com/ , here in western PA. They are very helpful and willing to answer any of my questions. If you call them tell them Ben from Bish Tool sent you. ( it won't get either of us anything, but occasionally I like to have my name dropped )
    There is information, such as service codes for machine callibration, that is not in any of the user manuals that your local distributor/service center can help with.
    I know of another great place to have your CRT fixed if it ever goes bad. They specialize in industrial equiptment and dedicate a whole section of their website to prototrak. They only charged us something like $235 to replace the dead CRT and install high temp capacitors and cure what they call "ProtoTrak Disease." SWI wanted like $800 to trade the whole pendant for a rebuilt one. Even if your readout is only slightly burned into your screen it's worth having it replaced. Total failure is only a stones throw away. This company uses higher quality components than SWI and should last much longer. If only I could remember their name off hand. If you need it PM me and I will get it for you.
    Machine movers are great. As long as they know of the challenges ahead of time; they'll be prepared and install will be a snap.
    Like I said, Saturday is the soonest I can take the cover off. It looks like there are only 4 standard screws holding it on. The only thing that might get in the way is it being Valentine's Day.
    I 'll let you know as soon as I have any more info for you. Till then read up on the operation and programming manual so you can get to makin' chips right away.
    Oct 2006
    73
    Here's the link to that CRT repair company. I liked dealing with them alot. They know their stuff and turn-around is fast. I just disconnected the cables removed the pendant from the support arm and shipped it to them with my billing and return info. Very easy to deal with.
    http://www.machinecrt.com/
    I said $235 for the repair, but their website says $295. Still a very good deal.
    Aug 2006
    10
    I pulled the cover off of the trak mill at work today. It measured 83 7/8" from the bottom of the base to the top of the counterweight spocket assembly. If you have some bars to block the counterweight, the assembly looks like it would come off pretty easily and give you about 3" more clearance. I don't know the size of the cap screws holding it on, but they are probably metric. Hope this helps.
    Sep 2007
    7
    Guys, thanks for the help. It’s good to have a heads up on this process. One mover suggested that I cut the header out of my garage. It’s structural, so I don’t think that will happen. 83 7/8 to the sprocket plus 1/8 inch for some steel sheet puts me right at 84 inches. It is going to be close! I’ll have pictures.
    Jun 2008
    230
    Quote Originally Posted by kentucker237 View Post
    Hi Kentucker,
    I did a similar move last summer when I brought my 1996 Feeler FV-800 home to my garage. I heard from the movers that it is quite common to slip a machine under a garage door opening on sheetmetal. They just oil it a little so the machine can slide easily and they only need approx. 25 mm extra hight to do it.
    I had the "luxury" of a 2250 mm opening so we could lift her right in with long forks and placed her on 3 "skates" as they call them here. It is small dollies with polyurethane clad wheels that are really gentle to the floor. One of them was a swiveling kind and we could easily rotate the machine inside the garage by hand pressure.
    Of course, the machine is higher than the opening, but I removed the Z-axis servo cover, motor and the counter weight's chainwheel blocks. I also had to loosen the cable chain and its square tube manifold and tilt the whole package sideways. No cables needed to be disconnected though.
    When I got her inside the garage I had to move it long enough to clear the garage door in its max. lifted position. It folds up under the ceiling and creates a new lower "ceiling". One more thing that is important (maybe not for you with the 9 foot ceiling). I have 2500 mm ceiling and the cable chain reaches 2750 mm in its upper position so I had to make a 280 mm high box to let the cable chain up through the ceiling. If you need that too, check very carefully that you do not have any structural beams, or something else above the cable chain area, preventing you from cutting the opening for the box. I measured everything in advance and made marks on the floor for an exact position for the machine. The movers placed it correctly within the millimeter.
    And don't forget to leave enough room behind the machine so that you can open the doors fully to the Electrical cabinet if it is there.
    Do you have enogh thickness in the concrete floor? I have 120-180 mm which work just fine for a 5 metric ton machine.
    What kind of driveway do you have? The movers vere more concerned about my driveway than the garage floor. Why? Well the truck is 9 tons and the machine is 5 tons. That is a lot of weight on the front axle. So they placed 10mm steel sheets on my driveway. I even placed a layer of 12 mm plywood (borrowed from a builder), before they arrived, to protect my drive way from being scratched.
    12 mm Plywood protecting driveway bricks
    10 mm Steel sheets on top of plywood sheets to carry the load
    Truck with machine on forks
    Dollies made it easy to roll on garage floor
    Z-axis servo etc removed to lower machine
    First I had 15 mm steel strips under the machine feet but it was a waste of time. I could not
    level the machine as it was to "spongy". I placed the machine directly on the floor. No problem
    at all, and rock solid.
    The finished machine. I will start a new thread later about the rebuild
    and all its aspects
    Good Luck with the move, installation & operation. And take many photos so you can post them here later!:cheers:
    /Peter
    I moved a DPM into my garage with 84" clearance height. I did take off the top cover. Also move head down as far as you can. I don't know if you know this but there are holes in the side base of the machine that are made to put round bars through so you can move the machine. This allows you to use a fork truck and get as close to the floor as you can. It's been awhile since I had mine moved( I did use a rigger),
    so not sure if we had to tilt it, but I do remember it was pretty close, but I got it in. good luck
    Sep 2007
    7
    CNC Viking: That Feeler VMC is one LARGE mill to squeeze into a garage. How many of us are feeling envious right about now?
    My driveway is concrete so that shouldn’t be a problem.
    These Trak DPM’s weigh about 4100 lbs. The local rigger has assured me that this will be fairly simple.
    Not too sure about thickness of the garage floor. I have some leveling pads (Airloc Wedgmounts) that spread the load. My only concern will be the wheels on their dollies.
    I had my own experience with my lathe and the electrical box door. Fortunately the lathe only weighs 1000 lbs., so it just meant a simple repositioning with the engine hoist.
    Clembrant: Glad to hear about your experience getting your DPM into your garage. Cuts my anxiety level way down. Thanks for the tip on the lifting holes in the side. I passed that on to the rigger so they can plan ahead.
    Yours looks about the same as mine: AGE 3 control and power drawbar. Nice machine. Could you lower the head enough for the power drawbar to clear the garage door or did it have to come off? My friend told me that there is a hand crank to turn the Z axis ball screw.
    Oct 2006
    73
    I may be wrong, but I think the Z axis hand crank is only on the AGE-2 And MX-2 model DPM's. The full 3 axis machines don't. Mine (MX3) doesn't.
    But don't worry, with the power turned off you can turn the ball screw by hand since you'll have the covers off. That is, as long as your counterbalance is working.
    Jul 2005
    12177
    When you have concrete floors and driveways moving a machine is dead simple, but sometimes you have to get creative:
    http://www.cnczone.com/forums/showthread.php?t=20113
    http://www.cnczone.com/forums/showthread.php?t=43657
    Sep 2007
    7
    The Prototrak is in the garage
    The move went extremely well. The sun even came out, as you can see from the pictures. Total time to move was 1 hour and 6 minutes. The mill was shipped on an enormous skid. I’ll probably make benches out of the wood.
    Getting it under the 7 foot garage door opening was no problem at all. There are 4 screws that retain the column cover. Removing the cover exposes the chain and sprockets for the counterweight. Once the cover is removed, the top of the chain is at about 6 foot, 9 inches. We also tilted the head over about 60 degrees. The forklift driver had no problem getting it through the opening.
    Once in the garage, it was easily maneuvered on their skates. Having a smooth, level garage floor helped. I thought about putting the mill in the corner at 45 degrees, but decided to go with the square placement shown.
    So if you have a conventional 7 foot garage opening, a Trak will fit easily. Something to keep in mind if you are moving one, is to support the counterweight so it doesn’t bang around. There is a hole in the side of the column that accepts 1 inch diameter round stock, about 24 inches long. About the only difficulty that we found was moving the head to lift the counterweight off of the support bar. The top of the ball screw has a small round nut (about 1 inch diameter) that requires a hook spanner to turn it. I didn’t have a spanner small enough, so we just muscled it.
    All in all, I’m pleased with having hired a professional rigging company to do the move. The rental cost for a forklift big enough to move this mill on the skid wasn’t a whole lot less than the cost of the move. And of course, I don’t know where to find skates like they have.
    Attached Thumbnails Attached Thumbnails Trak DPM in driveway with plastic wrap off, for posting.jpg   Trak DPM squeezing under garage door opening, for posting.jpg   Trak DPM on skates in garage, for posting.jpg   Trak DPM set in place in garage, for posting.jpg
  1. Screw Drive garage door opener
    By Kevin McFarl in forum DIY CNC Router Table Machines
    Last Post: 01-17-2009, 11:34 PM
  2. Squeezing a VM-1 under a garage door?
    By rustyolddo in forum HURCO
    Last Post: 10-19-2008, 03:41 AM
  3. Garage door height and VF2
    By l u k e in forum Haas Mills
    Last Post: 03-27-2008, 03:10 PM
  4. Door Not Opening
    By WASLYH in forum Fanuc
    Last Post: 10-31-2007, 09:09 PM
  5. Garage Door CNC Gantry Router
    By DougMorency in forum DIY CNC Router Table Machines
    Last Post: 02-20-2006, 08:57 PM
