587,466 active members*
3,109 visitors online*
    Aug 2020
    trumpf trulaser l3030 fiber
    Shortly we have a new laser cutting machine from trumpf. (the l3030 fiber)
    Most of the standard setting work well but i have an issue with cutting aluminum diamond plates 2.5/4 and 3/5 mm thick.
    wich settings and nozzle do u guys use for these plates.
    Greetings Nielske93.
    Oct 2015
    Re: trumpf trulaser l3030 fiber
    Are you measuring the thickness of the Diamond and using that tech table? For 1/8" Diamond plate I use the 3/16 tech table. You can also put the sheet on upside down, That some times helps.
