587,125 active members*
2,647 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Opinions: wood chop-saw to metal chop-saw duty
    Apr 2006
    17
    Question Opinions: wood chop-saw to metal chop-saw duty
    I picked up a heavy-duty Makita chop-saw at the dump. It is old & weighs at least 50 lbs. It is not a sliding type, just the basic chop with miter table. It needed some fiddling with the switch but runs fine now. The miter feature is broken though and it needs ~$50 in parts to get back to normal and is stuck @ 90-degrees. My thought is to make it into a metal cut-off machine. By seat-of-the-pants it seems to turn at similar RPM to chop-saws I've used previously.
    Any downsides on this idea?
    Jul 2005
    12177
    Will work fine with what is called a 'triple chip blade' rated for cutting non-ferrous metals. Just make sure you have something to securely clamp the material you are cutting. Use a bit of coolant either with an ait mister or just spray it on before cutting.
    Apr 2006
    17
    Quote Originally Posted by Geof View Post
    Thanks Geof, excellent reminder on using clamps!
    I should have specified I want to use this on mild steel such as angle & bar stock. I don't think the triple-chip blade would work for that.
    Re: coolant, I've never seen it used on a true chop-saw with an abrasive cut-off blade as below. Can you use coolant with an abrasive blade?
    Jul 2005
    12177
    You might make one cut on mild steel with a triple chip blade.
    Coolant is not needed with the abrasive cut-off blades.
    Oct 2009
    careful
    I have used an old chop saw to cut metal with an abrasive blade before. The one I used was originally made for wood, and it worked just fine. The only issues I had were that the saw had plastic chip shields in the bed and part of the blade guard was plastic too. The hot metal from the abrasive blade melted it a little. No harm though.
    Apr 2006
    17
    Quote Originally Posted by Welder1 View Post
    Great, that's what I needed to know.
    All responses very much appreciated.
    I will probably pick up a triple-chip blade for when I do work with non-ferrous stock.
  1. Metal Cutting Chop Saw vs Abrasive Chop Saw
    By diarmaid in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 11-24-2022, 06:31 AM
  2. should I chop up these MASSIVE linear rails?
    By KTP in forum DIY CNC Router Table Machines
    Last Post: 03-01-2009, 07:14 PM
  3. best basic chop saw
    By nc9933 in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2008, 09:10 PM
  4. Radial arm chop saw - bad idea?
    By roombacurious in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2008, 01:26 AM
  5. Need a saw to cut material, Band or Chop?
    By mgb1974 in forum Community Club House
    Last Post: 07-30-2008, 05:22 AM
