The attached file is a casting for which im trying to use surface toolpaths to machine the face which is 2mm down from the outside face, which has the 5.5mm slot through it, the surface is green(not the recess around the open face) I have tried using high speed horizontal toolpath with little success. Any help would be gratefully received
Thanks Julian
