587,380 active members*
3,227 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Letters not getting tool path
    Nov 2012
    162
    Hi guys. Just picked up MasterCAM X7 (Windows 7 Pro) and was trying to do some desk nameplates. Just letters .125 deep in aluminum. The problem is the capitols J and C (and the small i) are split in to two chains and dont toolpath correctly or at all. I set the letters to 2" high Brittanica Bold and tried a .125 bit, .0625 and finally a .030 bit. The tool path will not go around the lower part of the J to create a single toolpath.
    I measured across the area and got .450 or so the width is big enough for the tool to go thru. I have tried a couple different type of toolpaths such as highspeed and contour with the same results.
    I know it's something I'm missing but being new, I don't have a clue as to what to look for. What's missing?
    P.S. the tool shows correctly in the left hand window.
    Apr 2003
    3578
    Re: Letters not getting tool path
    Share your file
    Cadcam
    Feb 2009
    26
    zoom in on the letters where the chain is broken, you will find there is a break in the chain. you really have to zoom right in to see it.
    Hope this helps. :banana:
    Oct 2006
    There are a lot of fonts that don't machine well. Like he said the lines are bad or not connected.
    May 2014
    43
    Instead of chain option use the window function its right below the chain option in the same prompt window. Pick the area where the fonts are , pick an approximate starting point and off you go.
    Nov 2012
    162
    Sorry for such a delay in responding. Got real busy and didn't have enuff time for play. I'll retry the lettering and let you guys know the outcome sometime next week. Thanks for the replies.
  1. tool size concept- tool path generated vs gcode
    By kjl-pdx in forum Mach Mill
    Last Post: 03-12-2013, 07:25 AM
  2. CAM: Tool path generation for ATC Automatic Tool Changer
    By S.Seveelavanan in forum Uncategorised CAM Discussion
    Last Post: 08-09-2012, 04:45 PM
  3. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  4. Need Tool For Maching Letters and Numbers
    By SDETERS in forum CNC Tooling
    Last Post: 04-05-2009, 01:25 AM
  5. Tool approach Tool Path
    By Kiwi in forum BobCad-Cam
    Last Post: 07-05-2007, 08:35 AM
