587,246 active members*
3,162 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > how to cut a 85 degree v raise female tool
    Aug 2008
    52
    I want to make a v raise die with a 85 degree form in, who's got the best suggestion on how to cut this on my vertical bridgeport mill. (8" long 1 1/4 wide 5/8" deep approx)
    Nov 2003
    154
    Mount your part vertically. Use a form cutter for the shape you need. Form cutter (or holder) needs to be long enough so it is away from the spindle. The seperation between the 'V's is controlled by your vertical. The longer your cutter will be from the end of the spindle the more chatter you will see in your cut. You can also try a flycutter ground to the right form but may be harder to set up.
    This is all based upon if I understand what you are asking.
  1. Replies: 3
    Last Post: 06-30-2008, 01:30 AM
  2. 4020 Won't raise Z to allow tool change!!
    By john-john in forum Fadal
    Last Post: 05-16-2008, 06:53 PM
  3. knurling work need (female and male)
    By acerocket in forum Employment Opportunity
    Last Post: 02-10-2008, 10:24 PM
  4. Calculate tool offset for degree
    By CBNDude in forum MetalWork Discussion
    Last Post: 10-17-2007, 11:59 PM
  5. male and female molds
    By pyroracing85 in forum Moldmaking
    Last Post: 02-21-2005, 06:40 PM
