587,218 active members*
2,480 visitors online*
    Sep 2011
    QT15 - 20 NMI Emergency stop alarm
    Hello all ,
    Any help / advised is greatly appreciated.
    We have Mazak QT15 machine that has the above the error. Behind this we have further alarm 202 Hydraulic pressure down.
    We can clear the alarms and then run the machine only if we put some pressure into the slide way lube by manually pumping the injector.
    The machine runs for around 10 to 15 minutes and then alarms out again , this happens in cycle while using a peg.
    If we open the jaws after cycle to put a new part in , it alarms out straight away.
    Thanx
    Dec 2013
    5714
    Re: QT15 - 20 NMI Emergency stop alarm
    Maybe check the hydraulic pressure? Filter? Low oil? Pressure switch fail?
    Jim Dawson
    Sandy, Oregon, USA
  1. ALARM 20 NMI EMERGENCY STOP.
    By GPena in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-13-2022, 02:48 PM
  2. NMI 20 Emergency Stop Alarm
    By pcreek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-17-2019, 01:52 PM
  3. Alarm 20 NMI emergency stop and alarm 204 spindle controller malfunction
    By bdrotaru in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-25-2019, 04:36 PM
  4. Nmi emergency stop alarm
    By richalex in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-06-2015, 05:43 PM
  5. Alarm 128 QT-8 Emergency stop
    By grabolo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-22-2009, 07:24 PM
