587,683 active members*
2,948 visitors online*
    Jun 2004
    258
    New user needs your help
    Hello...
    I am trying to get a DXF drawing to work properly In Mach2.
    Here is the problem...
    The drawing is converted to G code and when I run this code in a CNC Simulator it looks perfect. But when I try and run it in mach2 a number of tool paths are not being cut.
    I have attached the DXF file and also the TAP file that I am using.
    If anyone has some answers it would be appreciated.
    cheers
    Attached Files Attached Files
    Feb 2004
    2337
    Ring me. I can help you.
    Being outside the square !!!
    6855
    did you make it a polyline?
    Apr 2003
    1079
    I bet you got it fixed by now, but what the hell.
    You should make sure you save your DXF in version 12 or 14 for best results, and make sure you explode all polylines. Sometimes polylines will work, but most of the time they screw up. Apart from that, it could be something in the post processor that is wrong. Or did you import the dxf into Mach2 and convert from within?
  1. Replies: 2
    Last Post: 01-25-2005, 05:26 PM
  2. New Onecnc user!!
    By smitty in forum OneCNC
    Last Post: 08-13-2003, 01:44 AM
  3. New user questions
    By John F in forum OneCNC
    Last Post: 06-27-2003, 04:13 PM
