587,220 active members*
2,606 visitors online*
    Oct 2004
    590
    X value stuck at 0.001
    Running a demo version of 2.21 on XP pro sp3 and the the x values all import correctly but show up on the plotter and plot as 0.001. Any ideas?
    Thanks.
    Chris
    Oct 2007
    51
    try setup\machine configuration\control settings\ and change (on miscellaneos tab) set coordinate resolution to 1.0 hit apply and save.
    Oct 2004
    590
    Quote Originally Posted by patcareyis View Post
    Yeah that did it. Thanks. How does that effect the accuracy of the Gcode? Is it just a display issue?
    Chris
    Oct 2007
    51
    Quote Originally Posted by OCNC View Post
    Chris
    If I remember correctly it just affects how NcPlot interprets the code.
    If there is code that does not have a decimal or has the redundant coordinates removed.
    It does not change your code just lets NcPlot know how to plots it
  1. stuck ram
    By RP Designs in forum Uncategorised MetalWorking Machines
    Last Post: 02-05-2010, 06:44 AM
  2. ATC stuck
    By guydrisc in forum Okuma
    Last Post: 11-22-2009, 12:14 AM
  3. Double arm stuck
    By roadking in forum Fanuc
    Last Post: 01-19-2009, 02:01 AM
  4. Help! am Stuck!
    By ImanCarrot in forum Uncategorised CAM Discussion
    Last Post: 11-16-2007, 09:34 AM
  5. SMTC Stuck. Please help!
    By Matt@RFR in forum Haas Mills
    Last Post: 08-11-2007, 02:02 AM
