Iam doing some experimenting with plunge roughing in V28 and cant seem to modify the start point of the cutter. As you know, most plunge cutters arent center cutting, so I cant just slam the tool into the material.
Any help is appreciated.
-Geoff
-Geoff
-Geoff Warner
VegasCarts.com & myVegasCarts.com
Can you use Spiral or Ramp lead in rather than plunging?
hi
in my experience spiral and compression cutters are noyt designed to plunge but ok to ramp in and out with a lead in and out.
I have been cncing wood for a number of years now and i always use a standard 2 flute cutter to plunge for a pocket cycle then come in with spiral cuttter to finish it off.
When roughing a componanant out i always leave .25mm on stock then come in and do a final pass,I hope this helps you
-Geoff Warner
Not by your first post where you didn't bother to mention that though! ;-)
It's easy to be smart about information you don't furnish to those you are expecting to help, why say you can't when you subsequently state you are using a tool which specifically can? Now you too have been enlightened! :P
The plunge roughing feature is a raster, simple planar strategy. Your control is a directional control called setting the lace angle, which will determine in which direction it rasters....
But a plunge rough is a plunge! there is no concern for plunging a tool into material in a plunge rough? What's the point!
You can set a peck amount.....
If you cant have the surface extended to then use a boundary to control where the first plunge occurs,(The first plunge becomes the full bit) you will need to add an operation to that area to remove the material another way....
You can add a planar surface to the geometry selection to extend the plunge out of the boundary half the tool distance (since it computes at tip)... That will allow the plunge to "nibble" into the rough....
