587,124 active members*
3,425 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Kitamura Mycenter 1 480 volt to 240 volt conversion?
    Dec 2006
    I have an opportunity to get a Kitamura Mycenter 1. It is a 480 volt machine but I only have 240 available. Does anyone know if it is possible to switch the machine to run on 240?
    MR
    Oct 2004
    The easy way to fix this is to look on ebay and find a 480 primary and 240 volt secondary transformer should be able to find one for few hundred dollars and wire it up backwards, like hook your 240 volt to the secondary and it will give you 480 volt out the primary and you can hook that to your machine ready to go and it will be clean....a 35-40 kva would be more than a enough to do the job... depending on the size or the machine
    24223
    If it is Fanuc based, it possibly has transformer taps for 220, if there are any 3 phase motors on 480, they often are dual voltage, 220-480, you might have to change the overloads/fusing, if changing over.
    Al.
  1. kITAMURA MYCENTER-1 Help needed again!!
    By aghobby in forum Fanuc
    Last Post: 11-16-2023, 07:35 PM
  2. Kitamura Mycenter
    By cdlenterprises in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2007, 05:25 AM
  3. Kitamura Mycenter 3B
    By sebaja in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2007, 11:22 PM
  4. Kitamura Mycenter 0
    By inertialabs in forum Shopmaster/Shoptask
    Last Post: 01-16-2007, 03:47 AM
  5. Kitamura Mycenter 1B Specs
    By Nauticalknowhow in forum MetalWork Discussion
    Last Post: 12-27-2006, 07:03 PM
