587,535 active members*
2,841 visitors online*
Results 1 to 20 of 34
Hybrid View
    Nov 2006
    303
    more rpms for spindle motor and spindle
    I have a tree 250 with a 3HP spindle motor with a VFD. Right now the motor turns at about 4800rpm with a final spindle speed of 4k rpm. We want to bump to a 5HP spindle motor and get to a final spindle speed of 8-10K. OUr spindle is an Erickson QC 30 taper with dual taper bearings at the head and three ball types up top. All are sealed grease. We are looking for a cheap 5HP 184TC frame, 4pole probably.
    We are looking for recommendations on brands of motors, max safe motor speeds, economical solutions, and what that spindle can take before we see issues with it. I know it scares most to wonder from the OEM path but we do it for a living in the race world.
    24220
    Quote Originally Posted by viper6383 View Post
    Wether or not the spindle can take it, I would say you are pushing the limit right now with a standard induction motor at almost 5k. Especially if you are looking at a cheap one.
    If the spindle itself can take it, I would look at using a larger HP standard motor and gear up. 3:1.
    At 10K the motor bearing and motor balancing are super critical.
    Al.
    Dec 2005
    3319
    I'll add this:
    Unless you know what kind of bearings are in the spindle (tapers, rollers, A/C ball, lite/med/heavy preload), simply over-revving the spindle can get dangerous and/or expensive.
    As you go UP in speed, you generally go DOWN in preload - you do that to reduce heat rise potential.
    Grease type (oil vs grease) and amount (lite for high speed, more is ok for lower speeds) also need to be reviewed and adjusted.
    In an economy of words, you can't simply double the speed of a spindle and expect it to live half as long - it might fail in 1/10th the time or maybe even sooner - or later. It really is too hard to tell.
    Yes, balancing are supler critical, but bearing alignments, fits, preloads and tolerances become hypercritical as speeds go up as well. NOT a place to SWAG unless you have money to spend/burn.
    If you do (have money and time to burn), buy a good high speed spindle and you'll be MUCH happier in the long run - you'll make more money too.
    Nov 2006
    303
    Well the spindle has dual A/C ball types at the bottom and three standard ball types at the top. The plan was to run our machine out at its rated 4K for X amount of time and allow the heating to meet equilibrium and then start pushing the Rs and monitor heating in the motor and spindle. We may install thermocouples on the spindle to monitor that since loading will have a large effect on heating. I have done some research on the A/C bearings and the minimum rating for any of them is 11K. Now I have no way of knowing which bearings I have until I go in. The thought was that if it "pops" we know the bearings were not good for it. A 500 dollar mistake but one that we would have to cross anyway since we are not taking no for an answer on more Rs.
    We would have to make a spindle bearing change anyway. We plan to build it ourselves and I know that would scare most people but we build race engines and parts everyday and I just love it when someone tells me I cannot do it. Actually, I am looking forward to it just to see what is going on there. Rest assured, I will school myself before attemping that.
    24220
    I don't see anyone is telling you 'You cannot do it' just pointing out the pitfalls that you may see when you do try.
    The rotor of a standard 4 pole 5 HP motor has quite a mass, I would be hesitant to be close this motor if you intend running it up to 10krpm. :nono:
    Al.
    Nov 2006
    303
    NO, no, sorry, I was not refering to anyone from the site. Actually, the reason I signed up is I saw several guys modding some custom mills and thought someone here cound help. Actually, I don't plan to push the motor further than 6-7K and plan to overdrive the spindle to 8-10K. I just rebuilt the motor today and found that indeed my spindle upper bearings are talking so it is time to check that out.
    Now my big and hopeful question on that spindle is can I install upper bearings without having to mess with the A/c Bearings at the bottom? I will bet someone overtensioned the belt and caused this failure and I am sure the A/c bearings are still good. I will also start another thread just on that to get some advise and that rebuild.
    B
    Dec 2005
    3319
    Famous last words " but the bearings were rated for 11,000 rpm...."
    Bearing "ratings" are theoretical values that the bearing should be capable of IF all the proper precautions for a particular environment are followed TO THE LETTER with all I's dotted and T's crossed. This also means that the bearings are warmed up prior to full tilt operation and all sorts of other normal and customary precautions. It also means proper lube and NO lube contamination.
    Believe it or not, there are people who install stuff, turn on the switch and expect it to run. Like buying a crate motor and trying to run it at Daytona to win the 500. Ain't gonna happen.
    High speed spindles typically run low preload bearings. THe better ones also tend to run constant pressure preloads as opposed to position preloads of the non-A/C support bearings. Thus, when the thing grows with heat, it doesn't start adding or changine preload in an unexpected fashion.
    Grease becomes less desireable a lube at high speed - oil/air mist becomes the preferred medium of lube. The air cools and the misted lube gives all the lube needed - the mist also doesn't cause the balls to hydroplane as grease or oil bath will/might at high speed.
    Your plan is valid and probably viable but there may be some legacy gremlins in your existing spindle design that may not be as conducive to high speed operation as you might hope. See if you can find some high speed spindle cross section dwgs - these would point out OBVIOUS differences that you should be aware of.
    The creation of a 10K spindle is NOT unike the attention to detail that the construction of a 9500rpm race motor entails. Care, details, premium hardware and patience. Without them, you can readily create junk.
    Yes, I am not telling you it is NOT possible - ony pointing out the challenges you face. one can never tell if the poster is a stroke or a PHD so, sadly, some of us merely assume lowest commond denominator in our replies.
    You also want to revisit your tool paths and infeeds for any part programs once you get the spindle built. Have seen where guys went to high speed and figured that they could do things the same way as they did with their high preload/bury the tool programs. Only comment is as followsnuts)
    Finally, there are no "that's good enough" "this is only DIY" excuses allowed when you're using/buidling H/S machine tool spindles. But you already know most of what can go wrong when one uses these bogus excuses if you do build race engines every day.
    Good luck
    Aug 2004
    2849
    viper6383....well it seems that you have all the answers....so go for it!
    Dec 2005
    3319
    If the upper bearings are whining and have started to deteriourate, they may have already transferred vibratory distress to the A/C's.
    If debris from raceway detriouration of the uppers got circulated thru the lube system, the A/C's are probably hurt.
    Pull the A/C's and wash them very, very well. Then get a magnfiying glass and look very carefully to see if the balls in them are "frosted" or have "cut lines" in them - ditto for the raceway. NEITHER should be present on either.
    If they are plastic caged, you can probably run them at high speed. Riveted steel cages are not as robust in high speed bearnigs as molded, reingforced nylon. Machined brass is OK but not as good as nylon
    Cut lines come from debris and or overload - frosting comes from lube contamination. Both dreastically shorten the remaining service life of ANY bearing
    If you do NOT replace the A/C's and they go bad later on, any misalignment generated will probably tear up the new top bearings. False sense of economics in my opinion but I"m not funding this program either.
    How lucky do you feel about your ability to clean, inspect, judge the integrity of used bearings as well as your "machine tool engineering, self taught" classes???
    The answer to this question would better determine whether or not to replace all the bearings as a one-shot repair.
    Nov 2006
    303
    NC Cams, I absolutely agree on replacement of the A/C bearings during repairs. I only ask because per OEM, the bearings should have lasted a lifetime. Actually, I am rather surprised the upper bearings are out since they are much larger and double stacked compaired to the motor bearings which were still good when I pulled them and replaced them. I know, *$%# happens.
    I normally would not question bearing replacement but the cost of the bearings alone is hard to swallow. Now you can bet I will do a full inspection while I am there but I was somehow (I know) hoping the uppers were an easy swap. I should know better anyway. I should note that the original reason for our mods was that we have a vibration in the mill coming from an out of balance condition somewhere. Runout checks could very possibly give us the answer we don't want.
    I agree that we need to better understand our spindle design and flaws. I am hoping that if we do replace the bearings, we can replace with better and higher rated bearings that will suite our needs better. I know the sealed grease bearing design could hurt us so I need to do some more research. Unfortunently, I really do need this thing apart to know what I have huh?
    Dec 2005
    3319
    Disassembling and reverse engineering to see exactly what you're starting out with sure beats the hell out of the buy something off of E-bay and make do/it'll have to work like some guys do.
    Once you "see" what you have, perhaps we can give more assistance.
    Dec 2005
    3319
    The upper bearings could have failed if they were subjected to contamination - environmental or particulate, it doesn't matter, same effect.
    Although bearings may have a theoretical mechanical capacity, most guys fail to consider grease life. Overheat it or contaminate it and the grease life plummets. That will cause premature bearing wear/failure REGARDLESS of the theoretical mechanical life.
    Either that or a over reefed on belt - perhaps a misplaced blow to "seat the bearing" could have resulted in a brinnell. Life often plummets like a rock when hammers and bearings meet.
    Or, if the spindle was position preloaded and got overheated, the expansion could have shoved the balls to the edge of the groove and consequently the balls got cut while running in that state.
    To prevent a recurrence, you're really gonna want to do a post mortem or else it could happen again - only with more disastrous results.
    There surely is a reason for the failure if you want to take the time to figure it out - I would if it were my spindle.
    Nov 2006
    303
    I will say that find the reason for a failure is exactly what I am known for in engines. Rest assured, and am very curious to find the reason for the failure. I will rarely put anything back together without answers. I agree and have been thinking about the bearing life and thinking a "freshen up" might be in order anyway since the bearings are 10 years old though the machine has set for several years. actually, I am wondering about rust pitting which is common for bearings not in use over time. Condensation kills.
    I am hoping there is a sub assy up top to couple the pulley assy to the spindle and it is a simple fix but either way, I am sure you are right that I will be right back in for a full rebuild by pushing the spindle up. I know we have to have the Rs. Would you have any idea what brand of bearings are supreme for this application? The A/C types I mean. thanks for your input.
    Dec 2005
    3319
    When you have sizes, I can probably fire off some premium bearing numbers to look for....
    Until then, you're guess is as good as anybody's...
    Nov 2006
    303
    OK, I am still digging that spindle out but I do have some numbers per the shop manual that might shed some light.
    The upper bearing is a 6009 P6 the P6 is confusing to me but more than likely an over seas manf.
    The A/C bearing numbers are B 7210 AATBP5 OL Have no idea on that one so I hope you do. I have found that cross referencing bearings from overseas can be tough and measuring is sometimes prefered. Thanks in advance.
    B
    Dec 2005
    3319
    Fairly simple BASIC interchanges BUT the numbers on the bearing do NOT give all the critical internal clearances.
    THe following are what I'd look for in NSK brand for the 6009:
    6009VVC3EP6 - 6009 size, VV (dbl non contact high speed seal), C3E (C3 clearance w/electric motor noise certification) and P6 (ISO grade of ABEC 3). In NSK, the next suffix is grease code and fill, NS7L or AKCL would be nice to get but you can always refill with your own grease if/when you find the size.
    Not familiar with ALL the numbers BUT this much is for sure:
    7210 = 7210 standard package size
    AA = ???, if it is contact angle, you need to find out what it is.
    T or TB = not sure BUT T alone probably denotes plastic cage
    P5 = ABEC 5 or ISO P5 accuracy grade
    OL = don't know but probably preload or maybe even "0" as is zero preload but doubtful.
    One of the unmentioned suffixes/prefixes probably denotes contact angle but I can't say unless I knew the brand name of bearings.
    As a starter, the 7210 NSK equivalent would be:
    7210CTYDULP4 where 7210 size is used with C (15 deg) contact angle, DU (duplex universal for DB, DF or DT mounting), L for "lite" preload and P4 for ABEC 7/ISO P4 accuracy.
    Depending on how the top bearings were installed/shimmed/preloaded, they may have a wierd clearance spec'd to make them self align with the preloaded bottom A/C's. This becomes MUCH more critical at high speed or with higher accuracy bearings.
    BTW, you'd better figure on regrinding the ID tool mount taper AFTER you refit the bearings. There was a Bridgeport spindle rebuilt thread that ran recently which explained why. Too long to go into again... Please search it out...
    Nov 2006
    303
    OK, I do have the drive assy in hand that couples the spindle shaft to the motor via a pulley system. The bearings there are also A/C type and made by ZKL so I am expecting ZKL in the spindle too. The bearings are 26degree, OD, 110mm, ID 70mm, W 20mm, rated at 7900/12000rpm grease/oil. They run a phenolic cage. The numbers are B7014 AA P4 OL CSSR PJPS. I talked with ZKL and they don't think this bearing was ever sold in the US so now I need to find a "reasonable" replacement for our application.
    I figure if I have the dims, and specs, I should be able to get what I need based on my criteria and not the OEM. Since I want more RPM, that needs to be addressed. Hopefully you can shed some light on what bearing to use thus far. Also, I am very curious as to what grease should be used for the higher speeds? Do you have a link of some good data on this? Thanks for the help
    Brandon
    Nov 2006
    303
    Since you are the authority on bearings it seems, I should ask if the removal of the A/c bearings by force of the outer race is a no no if I want to save them? There is no way of getting to the inner race to remove them properly and actually rather concerned on the upper drive portion that the bearings are good as they should have been a serious overkill for the application and feel flawless. My noises are eminating from the spindle bearings themselves.
    As I understand so far, A/C bearings are mostly bought "preloaded" which means the OEM preload is induced at the factory via some device, the inner/outer raceway offset measured, and the inner raceway ground so as long as the inner and outer spacer tubes are of the same thickness, the factory preload should be maintained regardless of torque nut torque? The method of putting just an outer spacer on will never yield acceptable ridigity due to inner raceway movement?
    What I really want to do honestly is recondition the upper drive bearings with better grease and maybe a different preload (when you tell me what that is) and run them. I will have to replace the spindle bearings and will have to pretty much start over with whatever is decided as long as the package size is the same. I can monitor heat rise of the upper drive and replace the bearings only after they are proved to suck for my application. Hopefully you can understand my reasoning. 1K for upper bearings and if they make change, they will not contaminate the spindle section.
    B
    Nov 2006
    303
    The grease you spec'd differs from the recommended lube of isoflex NBU-15 from the Kluber site. Just curious of reasoning on that.
    B
    Dec 2005
    3319
    7014A5TYDU( )P4 is an NSK p/n that should be readily obtainable that would be a drop in replacment. The ( ) denotes L, M or H for Lite, Med or Heavy preload. I can't read the ZKL code for preload amount - they should be able to advise if you located an office. L should work.
    The only difference is plastic cage. I don't recall the suffix for phenolic cages in NSK. Most instances, moulded plastic is preferred for high speed use.
    Again, for high speed operation, use L preload and also use a light fill of grease.
    For grease, a light fill of Kluber LDS18 should suffice. Hold your 'nads when you see the price but it is GOOD stuff.
