587,917 active members*
3,326 visitors online*
Results 1 to 11 of 11
    Feb 2004
    813
    Welder as a power supply??
    Hi Guys
    I've been busy buying up Copley servo amps; I now have 3
    They need to be fed 18-55Vdc at 5amp with a 10amp max (peak draw)
    I have an old welder that seems to be giving 38.9Vac the transformer is massive and can give 75amps max
    If I was to get a good sized bridge rectifier and some big a**ed smoothing caps do you think it could be used??
    opinions pleaseeee
    Apr 2003
    307
    At 39v ac you would get about 55v dc. That's 1.4 * Vac = Dc. There is no room there for any back EMF and might go over the max for your controllers.
    Chris
    Jan 2004
    490
    Sorry for the hijack question here Stevie. What about the transformer from an old microwave? They have big old beefy ones. Anybody know about them?
    Stop talking about it and do it already!!!!!
    Mar 2004
    1147
    I guess i would open the welder and see what is in it.. its probably something that you could modift to be more appropriate. i would guess most old welders would be fairly simple...
    Design & Development
    My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
    Jun 2003
    453
    I bought a portable mig welder from a guy who repares welders. The wire feed, leads and gun had been removed. All I had to do was buy some wire and put 7 more turns on the secondry winding and hook up the 3 capacitors he threw in an it's ready to use. This worked out to be very easy and cheap (A$50 for the welder and caps), I've not yet used it but it should be ok. Being built the way it is the welder will be able to supply what ever volt/amp requirements I'll need even if I upgrade to bigger servos, it's just a case of adjusting the number of turns on the secondry and possibly adding more caps.
    Splint
    Feb 2004
    813
    As I need a peak of 2500 watts; the microwave trans is out; but it is a good idea; I have an old one too
    Thanks for the replies guys; sounds like it might just work; i moved the slider in and the volts cut to 32; so i could keep it under 55Vdc; but I thnk the amps cut too; but I'm sure it was still over 40Amps
    24220
    One thing to keep in mind with welding transformers is the stick type arc welder has a loosley coupled secondary to primary winding, especially when the coupling bar is all the way out. this allows the voltage to collapse on high currents, as with a stuck rod etc. In other words it is not constant-current constant-voltage as is the case with a mig welder transformer. If your load current is well below the max current the welder is rated at you may be OK.
    Al
    Feb 2004
    813
    Thanks Al; as the total draw will be 30 absolute max; and the welder is 30-75 I can keep it low
    Feb 2004
    813
    Ok the dc will be 52.5 volts; this is 37.5Vac X 1.4
    The amps are anywhere from 20-75 by the info on the welder case
    The volts only max out when the rod is amost all the way out; they stay within 52.5 most of the way up
    I looked today in Radio Shack and the biggest bridge was a 50V at 25Amps
    Ill order one with some caps online
    What would be a good Value???
    Apr 2004
    439
    Feb 2004
    813
    Thanks Keys
    The amps can run on 18-55 Vdc so if it drops a touch in the bridge it will not be a problem
    Thanks for the links
  1. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 03:40 PM
  2. Diy Power Supply Choices
    By berin in forum DIY CNC Router Table Machines
    Last Post: 07-13-2005, 09:47 PM
  3. 5 Volt Power Supply Tripping
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 02-28-2005, 04:05 AM
  4. Choosing a Power Supply for Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2004, 04:36 AM
  5. Mig Welder Power Supply for Router?
    By samualt in forum CNC Machine Related Electronics
    Last Post: 10-11-2003, 02:51 PM
