587,753 active members*
3,041 visitors online*
    Nov 2005
    32
    cutters for cnc router
    Hi, I have been using trend cnc mini spiral downcut cutters for most of my cutting, (model aircraft bits). The most popular cutter I use is the 2mm diameter cutter with a 6mm cut depth. This causes a problem when cutting 1/4" balsa for obvious reasons.
    Does anyone know of a uk supplier of spiral cutters, preferably 2mm diameter, that have a cut depth of greater than 6mm, 8mm would be ideal.
    Mike
    May 2005
    73
    router cuters
    try this site www.vhf.de they are in germany i ordered a small quantity of cuters and had good service from them they sent the order within a week with catalogue and loads of info and a free mouse mat I cut 3mm light ply four my kits
