587,470 active members*
3,174 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Looking for 10A stepper driver leadshine?
    Sep 2019
    44
    Hello,
    I'm looking for a good driver to feed a 2 phase 10 Arms stepper motor.
    At the moment i have leadshine drivers up to 7 Amp, but if i look into their range the have no drivers above 8.8 amp.
    Anyone that can recommend a good driver that handles 10 amp
    Adam
    May 2015
    686
    Re: Looking for 10A stepper driver leadshine?
    Lam Technologies LS1098 unframed and DS1098 in a case are 10 amps (same electronics)
    https://www.lamtechnologies.com/Prod...=EN&idp=LS1098
    https://www.lamtechnologies.com/Prod...=EN&idp=DS1098
    But they are rated at true amps not RMS like Leadshine et al so it will have more boot than you might expect.
    These drives are the best you can buy. Their boost technology is amazing. Here is a video of my plasma table where I explain it.
    https://youtu.be/7UTk5eVCPGA
    Our modelling says that the torque required while at constant velocity is about 30-40% of the requirement when accelerating (depending on the motor) so by dropping the current when its not needed lets the motors stay cooler and avoid missed steps. Without boosting, we had to reduce the current to the drives or they overheating.
    Ooops, I forgot to mention in the video our acceleration is 5 metres/s/s (or 0.5G) and 35 m/min rapids (1380 ipm)
    Rod Webster
    www.vehiclemods.net.au
    Sep 2019
    44
    Thanks for the info! Will look into it!
    Dec 2013
    5716
    These are very nice drives, I have several of them.
    https://www.automationdirect.com/adc.../stp-drv-80100
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2019
    44
    Thanks for the link, will look into it!
    Already opened a new topic with some more concrete info/questions:
    https://www.cnczone.com/forums/stepp...ml#post2423346
  1. Toasted a Leadshine Driver 3ND883
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 05-24-2017, 02:12 AM
  2. Replies: 0
    Last Post: 04-27-2016, 10:05 AM
  3. Stepper driver problem (leadshine m742)
    By laserflight in forum Stepper Motors / Drives
    Last Post: 03-22-2011, 04:10 AM
  4. Leadshine DM556 stepper motor driver.
    By Kingjamez in forum Stepper Motors / Drives
    Last Post: 08-02-2009, 03:22 PM
