587,101 active members*
4,175 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > MV Junior Spindle Speed way too Slow
    Question MV Junior Spindle Speed way too Slow
    Hi Folks!
    I'm working on a project to revive a Mori Seiki MV Junior VMC with a Fanuc 10M Controller for quite a while now..
    Great progress has been made, as the machine (axes) and controller are now working almost entirerly. :banana:
    One problem stillt troubles me:
    When Im in MDI mode und try to run the spindle, just for testing (without tool) with:
    S1000 M03;
    then the spindle turns ON, but it turns only very slow! The movement also seems a bit irregular and not smooth.
    That means around 4 RPM or so. If I command an other RPM, the speed does not seem to adjust.
    If I turn the spindle off again and try to spin it by hand, it turns freely without any problems.
    The machine does not report any alarm or problem whatsoever.
    Previously, I have been resetting the machine completly, meaning entering all parameters, Options, Timers, Keeprelays by hand.
    Can this spindle behavior be the result of a wrong parameter?
    Thanks for any advice!
    Re: MV Junior Spindle Speed way too Slow
    Hi Again
    I found the problem.
    It was an incorrect setting of the PMC Data Table.
    The max. spindle speed is defined there.
  1. Replies: 0
    Last Post: 11-24-2018, 07:16 PM
  2. MV Junior, OT100 Spindle alarm
    By godzila in forum Mori Seiki Mills
    Last Post: 12-19-2013, 04:56 PM
  3. MV Junior Spindle Issues
    By alc1960 in forum Mori Seiki Mills
    Last Post: 02-09-2010, 01:16 AM
  4. Slow Spindle Speed
    By mikemill in forum Syil Products
    Last Post: 01-20-2010, 01:48 PM
  5. Help. Slow speed
    By shamus13 in forum Mach Mill
    Last Post: 12-08-2007, 06:06 PM
