I'm running a 3-axis homemade cnc machine with 3 xylotex 23H276-28-4B motors in it. My main type of material I am cutting is .75"-1.50" MDF Board. For example, most of my projects are 12"x19"x 0.75" thick. I import my design into Cut3D and that produces my Gcode. I have my feedrate set at 75 ipm and my plunge rate at 75 ipm spindle speed of 20,000 and am cutting with a 1/4" dia square bit in Cut3D, but when I run it on Mach 3 it almost takes an entire day just to cut out my design. Any solutions that can fix my issue? I believe its the feedrate that's my problem but should the spindle speed be set at a certain speed while in Mach 3? any and all help would be greatly appreciated!
Thanks to everyone in advance!
Marty
