Originally Posted by
nlh
NJC,
Looks like your post processor needs to be edited. I've attached the post that I use for my Okuma lathe. I still end up doing a little hand coding afterward. Always a good idea to check the code anyway.
Not sure how to help on the G75 code. I typically don't use the canned cycles other than threading. However I have changed quite a few things in my post so it may output what you need.
Oh, by the way, if you haven't used the Okuma graphic function, you really should. It's pretty basic but will help you spot trouble areas. Use MACHINE LOCK before pressing the START button!
Nate
