587,775 active members*
2,860 visitors online*
    Feb 2008
    4
    Sharnoa Tiger 4 DNC help
    We just purchased a used Sharnoa with a Tiger 4 controller and need to find out what the file extension will be for the NC output. Also, if anyone is currently using Surfcam and has a post for the tiger 4 I would really appreciate a copy!!!
    I have a tiger 3 and I have to strip the extension off form any file that I load or run under dnc. Not sure if the tiger 4 is the same, but you can try it. As far as a post, the sharnoa is somewhat generic in g code. I've never used surfcam but the turbocam that I use allows me to configure the output. Line numerlization, limits on G2 and G3 to 180 degrees, etc. I open the generated program in notepad and have to remove some extraneous code at the beginning of the program and after that it usually runs well. remember that the file name has the dos limitations.
    Andrew Abrams
    Marcellus Metalcasters, Inc.
    Feb 2008
    4
    Thanks Andrew,
    I'll try that and see if I can get it to work.......I'll keep you posted.
    Sep 2008
    67
    Hi all
    We just purchased a used Sharnoa with a Tiger 4 controller and need to find soft for machine computer
    Plees help us of you hav it send by email
    [email protected]
  1. Sharnoa tiger 6
    By shelburnebri in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-04-2021, 11:25 AM
  2. Sharnoa Tiger 6 upgraded to 2000 or XP?
    By CTD in forum DNC Problems and Solutions
    Last Post: 03-14-2021, 05:49 PM
  3. Sharnoa Tiger 4 post
    By shaydog24 in forum Post Processors for MC
    Last Post: 09-29-2007, 09:05 PM
  4. Lemoine vs Sharnoa controller
    By metalcaster4jc in forum CNC Machine Related Electronics
    Last Post: 03-01-2006, 08:01 PM
