587,791 active members*
3,056 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Need New Toolsetter Probe on Lynx
Results 1 to 13 of 13
    Feb 2011
    80
    So I crashed the tool setter probe on the Lynx 220. It damaged the top button on the probe part. I have checked into getting a new one and they are $800 plus just for the part. Does anyone know if anybody rebuilds these or sells rebuilt ones? I guess I have a hard time believing everyone is just throwing them away when this happens. Attached is a photo of it. The X- is the sensor that is broke. Thanks
    Jun 2004
    511
    Re: Need New Toolsetter Probe on Lynx
    Ebay is a gold mine for such items. I sold a new tool-setter in the box for 100$.
    Feb 2011
    80
    can they be repaired?
    Jun 2004
    511
    If you don't use X+ just flip it over and switch the wires. I don't know of a source for pieces parts for them.
    Feb 2013
    788
    I don't know if I've looked up your exact part (as I don't have your full serial number) but the newest Lynx 220 (starting serial series is ML0013) uses part number 301308-00287.
    It is in stock and lists for less than $700.00
    While it is possible that you might use a different version, I can look up that specific item if needed...
    If you'd like me to check, please supply the whole serial number.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2011
    80
    That is the one I have..........301308-00287. The problem I have is that Doosan distributor wants over $800 USD for it. Do you want serial number off of the lathe?
    Feb 2013
    788
    Yes, please.
    The complete serial number from the placard near the main power switch...
    Feb 2011
    80
    It is: ML0027-001394 Thank you
    Feb 2013
    788
    That is a Lynx 220 LMA (L=Long body, M=live milling, A=Bore size small )
    Your parts book shows:
    Item# Part# Description Spec Maker
    0510 EUNIT0196 SENSOR. TOUCH 4P-23-8-L E-SUNG
    We don't have that one in stock.
    From a Lynx 220 A parts list:
    0510 301308-00287 SENSOR;TOUCH A90K Marposs
    In Stock.
    This is Compatible.
    Feb 2011
    80
    Sounds Great! Where can I order it?
    Feb 2013
    788
    Confirm compatability from attached.
    Feb 2011
    80
    that's it....confirmed
    Feb 2013
    788
    Where are you located? (PM me if privacy is needed)
  1. Retrofitting 2006 VF2 with Renishaw Probe and toolsetter
    By JMFabrications in forum Haas Mills
    Last Post: 03-03-2014, 03:45 PM
  2. Doosan Lynx Tool Probe Question?
    By colton_m in forum Daewoo/Doosan
    Last Post: 07-14-2013, 12:45 PM
  3. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  4. Probe and toolsetter suggestions?
    By REVCAM_Bob in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2008, 01:12 AM
  5. Building Touch Probe and Toolsetter...
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 05-23-2007, 12:43 PM
