587,744 active members*
2,991 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > new retractable 56,000 Air spindle, Syil China / Syil Canada / Syil North America
Results 1 to 7 of 7
    [nomedia="http://www.youtube.com/watch?v=HAYo7il3jxs"]YouTube- Syil's retractable 56,000 rpm air spindle[/nomedia]
    SyiL is pleased to announce the first bolt on retractable high speed engraving spindle, SyiL has been working hard with SyiL Canada to design new cutting edge components for the mid-size CNC market.
    Syil's new bolt on retractable air spindle utilizes a 56,000 rpm air spindle, this air uses a small CFM footprint. This low volume CFM spindle allows any user with a small compressor to run this advanced air spindle.
    Our spindle allows users to use the main spindle and the engraving spindle in one program. This can be a essential component for manufactures that are required to serialize part as this can be done with in the same set up.
    The retractable high speed engraving spindle is also essential to the home hobby user, as this type of spindle allows for intricate, artistic engravings. As prior to the air spindle, due to the 3500 rpm spindle max engraving was painfully slow and very hard on tools.
    Our retractable air spindle was specifically designed for engraving, our spindle is not to be used for general purpose milling. Through all of extensive testing we have found either single point carbide engraving endmills or 4 flute pointed carbide endmills to work the best. We have also found that it is best not to have the tool not extended far out of the air spindle.
    If you like this bolt on component, you have not seen nothing yet!
    We have been working hard to design the most advanced, affordable, hi-tech components for the mid-size CNC market. SyiL one of the few true manufactures of CNC mills and components, most other sellers on the market just purchase OEM machines from manufactures and sell them. SyiL is proud to be one of the original producers of the table top CNC mills and lathes. Syil does not use other dealers electronics, but develops our own proprietary electronics.
    More bolt on / retrofit components to come!!!!
    Available for pre-sale NOW!!!!
    Apr 2006
    844
    Direction,Commitment,Follow through
    Apr 2006
    844
    here is some video of our machines.
    [ame="http://www.youtube.com/watch?v=FN_lpUVrdpg"]YouTube- SYIL CNC X7 video.wmv[/ame]
    we also have a lot of new design coming,please take visit at Syil.net
    Apr 2006
    844
    SyiL Power Drawbar/prototype ATC system.
    [nomedia="http://www.youtube.com/watch?v=VdPr085JLac"]YouTube- Syil's Bolt on power drawbar, for tabletop cnc mills[/nomedia] Please check the video.
    Syil Power draw bar,
    We are pleased to announce Syil Canada has engineered the only professional bolt on power draw bar system specifically designed for bench top mills. Syil Canada has worked extensively in collaboration with Syil china to engineer this ground breaking advancement. This advancement will change the whole bench top CNC market. This design will also work in cooperation with our bolt-on automatic tool changer.
    Our proprietary design has endured hundreds of hours of development, prototyping and testing. The main emphasis of our design is to provide no load to the spindle bearings, compact size and light weight. All of these factors are crucial to safe and non-destructive use of a power draw bar system.
    more info please visit www.syilnorthamerica.com
    Apr 2006
    844
    here is some pic of syil machine size compare.
    from x7,x6 big table,x6,x5,x4
    Apr 2006
    844
    Apr 2006
    844
  1. Replies: 39
    Last Post: 08-07-2010, 04:59 AM
  2. syil canada back from china!
    By syil canada in forum Syil Products
    Last Post: 08-23-2008, 02:02 AM
