Originally Posted by
dertsap
replacement KBLC-19PM (on order)
put it through a quick test as is and it seems ok , I did a bunch of milling on an aluminum block and it cut pretty well on the outside profiles and internal bore ,
I started small with a 1/4" 4 flute end mill , 50% engagement with a .05 depth of cut(ramped) , 50ipm at 4500 rpm . I'll test it later with some bigger tools and see what happens , if it holds up as it has then it should be ok , it's certainly nothing to impress with but it may turn out to be ok ,and hopefully much better with the new electronics , it still seems to me that the spindle setup is a joke as is the plastic gearing
