587,657 active members*
9,343 visitors online*
    Feb 2004
    21
    Vexta C6244-9212K Specs
    I'm trying to find a spec sheet on the Vexta C6244-9212K. It is marked 5.7V, 1.6A, 1.8degrees/step. I am looking for info on holding torque, and inductance.
    Oriental Motor is no help at all-it's as if they never made this motor.
    Anybody know where to find specs on the older OM Vexta stuff?
    Andy Wander
    Andy
    May 2004
    198
    Quote Originally Posted by awander
    Andy Wander
    It's a special order stepper for an OEM and Vexta won't help, trust me.
    5.7V at 1.6A suggests its close to 90oz-in.
    Dave Rigotti
    HobbyCNC.com
    Jul 2007
    I have a couple of those too,and am looking for some wiring info , so if you find it before I do please post it , and I will do the same
    Feb 2004
    21
    Win:
    Based on advice from Mariss at Geckodrive, i have mine hooked up Half-winding, drive set at 1.6A (15K current set resistor).
    Wiring is as follows:
    Phase A+ to BLK
    Phase A- to YEL
    Phase B+ to RED
    Phase B- to WHT
    I have BLU and GRN capped off.
    One of the coils is BLK-YEL-GRN(where YEL is the Center Tap) and the other is RED-WHT-BLU.
    Coil Resistance is 7.2 ohms full-coil, and 3.6 ohms from the center-tap to either end.
    I use this motor with my dividing head, with a total reduction of about 227:1 from the motor to the rotary spindle.
    Andy
    Andy
