587,905 active members*
2,873 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > where to find specs for vexta motors
    Dec 2004
    312
    i have VEXTA Brand Model is PK268-E2.OB
    and i tried google and no luck so far...
    the info im trying to find.. how much voltage does it require so i can figure out for the power supply issue..
    im going to get 2 1200 oz/in motor from ebay or homehobbycnc or something like that
    and one 90 oz/in motor for 4 axis setup.. any suggestions for power supply too? (voltage) 24 or 48 or 60 or 80 or something like that
    im not experienced in this area.. so im screaming for any help i can get
    Quote Originally Posted by DanOSB
    http://www.orientalmotor.com/product..._B267-B288.PDF
    With different size motors, you may need different size power supplies for each one.
    Dec 2004
    312
    ok i got those details..
    8 lead
    187 oz-in holding torque
    2 phase
    2 amps
    4.5 voltage
    2.25 resistance
    3.6 inductance
    now im wondering if i can run 48 volt on that stepper motor? how can i find out what voltage that motor will allow? or i only can run 4.5 voltage.. like i said earlier i know nothing about electronics
