587,594 active members*
4,056 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Another G0704 Build - Hoss Plans!
    Nov 2015
    Hey All,
    New guy here on the forum, but wanted to chime in and post my progress for others to see, and to give a huge shout out to Hoss for all of his help both on previous posts and personal email responses. It's so incredibly helpful, and much appreciated!
    Purchased my G0704 last month from the Bellingham warehouse. I'm only about an hour away so it made a lot of sense. I wasn't planning on doing the CNC conversion so soon, but some other side projects have pushed it forward as it will allow me to make some tools I would have otherwise had to have paid someone to make. As a side note - I'm pursuing building mountain bike frames and I purchased the mill to support that end goal - making tools, mitering tubes, and custom small parts.
    So far I've just done some basic mods: Tramming aids on the head, and DRO's added to X,Y, and Z axis - but still need a display mount.
    I purchased Hoss's plans for CNC conversion and planning on just doing the phase one update to get going the cheapest way I can, as I have some "immediate" needs for a few tools that I'd like to make. I plan on adding the phase 2 ball screws eventually, likely next year sometime.
    So far I just have the stock cut to size and the X axis mount plate is completed. I got a boring bar so it was my first attempt using that and I think it turned out pretty well! I'm a little unsure about procedure for doing a counterbore with it (needed on the Y-axis spacer) but that'll come next.
    I'll keep updating this thread as I make progress and have any issues or questions. As I get time I'd like to also summarize some of the "newbie" questions I asked Hoss via email that he was so kind to respond to, so that other newbie's might find it as well.
    Attached Thumbnails Attached Thumbnails Mill.jpg   FullSizeRender.jpg   FullSizeRender_1.jpg   FullSizeRender_2.jpg
    Apr 2016
    15
    Re: Another G0704 Build - Hoss Plans!
    If things go as planned, I should be in almost the exact same position as you in about a month, so I'm looking forward to seeing how things go!
  1. Re: Hoss G0704
    By bgriggs in forum Benchtop Machines
    Last Post: 06-04-2016, 04:36 PM
  2. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  3. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  4. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  5. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
