587,237 active members*
4,350 visitors online*
    Nov 2005
    157
    Lifting Bar Size?
    I finally uncrated and moved my new Series III home after months of storage, and an getting ready to lift it and move it into place.
    Should have bought the lifting bar (but didn't) and as I'm the UK it's a bit late to order one now, so I need to make one up in my workshop.
    So..does anyone have the centre distances handy that they could share please? Obviously I need the the 2 outer hole centre distances and the distance from one of them to the centre lifting point hole.
    Thanks for any help you can give.
    Peter
    Nov 2005
    157
    Never mind, I've worked it out and made it together with the tee-nut for the table eyebolt.
    I reckon you must have all gone fishing
    Jan 2012
    714
    I just used a chain on mine between the columb and table, I made a loop in the chain to hook to the hoist, worked out Ok. I couldnt see spending upwards of 100 dollars for a one time use item.......
    mike sr
    Sep 2005
    540
    I bought one from HF for about $30 but never used it in moving the mill... However, It did come in handy when moving my router.
    Jun 2012
    59
    I used the one from HF. Works perfectly for 1/3 the price, AND is adjustable so you may actually use it again.
  1. G0602 lifting?
    By thewoodnerd in forum Benchtop Machines
    Last Post: 10-18-2011, 04:05 AM
  2. Austin, TX. Anyone got a lifting bar I can use?
    By TXFred in forum Tormach Personal CNC Mill
    Last Post: 05-21-2011, 03:56 PM
  3. Lifting the beast
    By cyclestart in forum Benchtop Machines
    Last Post: 04-03-2011, 03:50 PM
  4. Lifting Mill?
    By CROSSHATCH in forum Charter Oak Automation Support Forum
    Last Post: 11-22-2008, 08:33 AM
  5. z axes lifting
    By John Teichman in forum Mach Mill
    Last Post: 02-11-2008, 04:12 AM
