587,086 active members*
3,034 visitors online*
Page 1 of 5 123
Results 1 to 20 of 113
Hybrid View
    Aug 2008
    573
    PIC based DRO
    Continued from Welcome thread
    Look like you haave been busy. The engraver looks great.
    I would be interested in how you used the PICs for your DRO`s. Did you design them yourself?
    I wonder if they could work using encoders ?
    Mario
    The DRO (still work in progress) uses one 12F675 per channel to read the digital scale. The outputs of four PIC are multiplexed into one serial port of a PC. The PC runs a VB5 application that displays the readings (see attached).
    The layout of the main form is designed to match my homebrew PC's touchswitches that are arranged down the left and right sides of the display
    I spent sometime getting every thing to talk to each other neatly, so for instance, you can plug an extra vernier/scale into the adapter block and it just pops up on the screen.
    As to using the PICs with quadrature encoder, I'm sure the little 8 pinners I've used lack the necessary hardware (you'd need a couple of fast counters to ensure no pulses were lost). The ones to use would be the dsPIC devices like the 30F4012 (?) which have the quadrature hardware inside.
    Nov 2003
    154
    Could you post more metails on the project. I have been playing in various pics of the past year and would like to get a little more advanced in reading other pulses.
    Aug 2008
    573
    Quote Originally Posted by mc_n_g View Post
    What pulses are you trying to read?
    Nov 2003
    154
    I am trying to do a better job in understanding teh analog and digital side of the processing. I have played with temp sensors and other simple items for input. I have not worked with any encoders at all. This is where I am lacking examples and expereience.
    Aug 2008
    573
    I'm not actually reading encoders. I'm decoding the digital data outputs of those cheap Chinese digital calipers (see :examples here). To keep my circuit simple, I'm using the PICs onboard comparitor and reference to convert the low level (~1.5v) signal to one that the PIC can read.
    This circuit is of a single device reader powered by the serial port.
    The LEDs (D1,2,3) limit the voltage to about 1.2v when the PIC drives the scale's inputs.
    Jul 2011
    Smile
    Quote Originally Posted by BillTodd View Post
    Hi Bill, Interesting Thread, But will you please repost the image..... I found a broken link here.
    Also if can you please refer any PC Interface for Magnetic Linear Scales.:withstupi
    Jun 2007
    20
    Unhappy
    As to using the PICs with quadrature encoder, I'm sure the little 8 pinners I've used lack the necessary hardware (you'd need a couple of fast counters to ensure no pulses were lost). The ones to use would be the dsPIC devices like the 30F4012 (?) which have the quadrature hardware inside.[/QUOTE]
    Hi Bill. It all looks impressive. You have certainly done a good job. I wish I had your talents. Unfortunately I am just a Trial and error learner at both electronics and Cnc`ing If i had one wish it would be that there was a way to verify my steppers with an encoder in Mach 3. A task too difficult for me with my limited experience.
    Marz
    Aug 2008
    573
    The usual method is to mark the motor's starting position accurately, then run a torture test (i.e. a test that runs the motor at various speeds back and forth until finally return ing to the start point), then check the motor has returned to the start postition correctly.
    Jun 2007
    20
    Yer Bill. I have done all that. I set up a dial indicator on both axis and then ran a g code program with rapid moves for a 1/2 hr. I tuned the motors for 10% under the max revs before it misses pulses. Its just sometimes if I push the toolbit too hard it misses a few steps. I know thats my fault, but it would be nice if it could correct itself. If only I had the money to run servos....
    Marz
    Aug 2008
    573
    I see. Can mach3 do that, if it has encoder/count inputs?
    What sort of input does Mach3 need?
    Jun 2007
    20
    I`m not really sure.I was thinking along the lines of another pic or such countin pulses and comparing the result with an encoder (sort of like a virtual closed loop system) and if it misses steps using one of the inputs to signal a positioning error
    Marz
    Mar 2007
    534
    I'm brewing up much the same but with a home made computer board reading scales and stepping motors.
    The step timer interrupt compares "where I am" with "where I want to be" and steps accordingly.
    The "where I am" can change at any moment should a report be received from any of the 3 scale interrupts. (I read them with hardware because any lag will only serve to confuse it).
    At the end of an x,y,z stepping sequence it works out the error on all 3 axes. Should any be outside tolerance it doesn't update the "where I want to be" to a new position. This means I get remedial steps to put it back on course.
    Questions are, wil it do more remedial steps than moving steps, and, how tight can I put the tolerance
    I only have to mount the scales and I can find out
    Aug 2008
    573
    Quote Originally Posted by Robin Hewitt View Post
    Interesting idea Although,the missed steps may not be able to be corrected until the cause has been removed.
    i.e. if it drops steps because of excess speed v load, will there be time to correct them before the next motion without increasing the frequency of the pulses thus exacerbating the speed v load problem?
    (Well worth trying though )
    Mar 2007
    534
    The fast traverse is a completely separate interrupt handler, precise placement only happens at speeds where the motors can handle an instantaneous reversal.
    There is more work to do. When it encounters back lash it will tend to trail by the tolerance and I will need extra remedial steps. OTOH I'm not going to try to fix anything until it has had a chance to tell me what needs fixing.
    I'm writing the code and everything runs in SRAM. I can recompile and upload all new in a matter of seconds. I am in control
    Aug 2008
    573
    Yeah. you could be right, but steppers and encoders on ebay are a lot cheaper than servos, and if a cheap PIC could be made to act as a Pseudo closed loop it would be just as good for a lot less money for the Dyer's
    "just as good.." No, I'm afraid not.
    If a servo system requires speed to catch-up with the commanded steps all it has to do is dump more power into the servo motor (right up to the point it/something goes bang or hits a power limit) . A stepper motor driver cannot do this. The best a closed loop stepper system could do is to wait until the overload event has passed then add pulses to get back on track.
    Now let's assume the above error occurred while cutting material with multiple passes ( caused by a knot in a piece of wood for example) ; both would have left a 'bump' of uncut material. The servo system would have probably left a smaller bump than the stepper (since it had more power available to attack the bump), so subsequent passes would likely reduce the bump. The stepper system would have to leave the bump untouched and add to the bump while it waited to correct the error. Subsequent passes are very likely to stall again at the initial bump and... well you can see where it's going.
    Mar 2007
    534
    If you overload a stepper to the point where you lose steps everything thereafter is garbage. That's why us stepper people tend to drive them way below capacity. I have more than enough power to snap the tool but I try not to use it
    With the scales attached, theoretically if it can't cut the material all 3 axes stop, possibly within 0.02 seconds depending on the tolerance. The repeating step pattern will cause it to back off and then try again and again until it succeeds, or not as the case may be.
    Aug 2008
    573
    That would be the advantage of taking control at an earlier stage in the system.
    Although, If your steppers aren't losing steps (because you're driving them well within limits) why do you need the recovery system?
    Mar 2007
    534
    Not so much a recovery system, more an external reference to locate the table without depending on everything staying in adjustment on a cheap mill
    I have a certain amount of spring in the system. The Gibbs are tighter at the ends where I rarely stray making backlash a variable. Changing pressure from the tool makes it unpredictable.
    Aiming to better 1 thou accuracy has become a sort of Grail quest... Not quite sure what I'd do with it if I found it but I feel compelled to try
    Jun 2007
    20
    Hmm..I think i found another hole im my theory about using pics to link encoders to steppers.It would be feasible to control one stepper that way but I guess would be a problem when integrating X,Y, and Z when interpolated on a g2 for example. If one took a bit longer to correct a couple of missed steps, it would throw the whole move out of wack. I guess you could have some way of all 3 PICs knowing what each of the others is doing.
    Jul 2009
    20
    Comparator Overview
    Bill,
    I am having trouble simply reading the 90KHz clock single from the scales using just about every method I can think of, be it through a separate comparator, an opamp configured as a comparator, and even a combination of NPN and PNP transistors.
    Can you give us a little insight into how you are using the comparators on the chip to accomplish this and as well a little description of why there are LEDs connected to the clock and data lines.
    I've also read conflicting info on whether or not the signal from the scales is +1.5v high and 0 low, -1.5v high and 0 low or some combination of those. I have an oscilloscope being delivered today which should help ME see what's going on.
    As of now, all I see is 3 "pulses" per second on the clock. However, using a homebrew soundcard oscilloscope technique I can definitely see that it's outputting the usual 2*24. Unfortunately the card doesn't record fast enough to see the clock, just the basic outline of it which looks like this _/-|-\_ (pardon the wonderful ascii rendition) hehe The -'s there are obviously the clocking which ends up somewhere between high and low because it can't resolve on the soundcard.
    ok so I'm all ears.
    Thanks!
Page 1 of 5 123
  1. Is water based
    By cncadmin in forum Safety Zone
    Last Post: 10-19-2022, 05:10 PM
  2. Need help with CNC UK based
    By ciscoe in forum European Club House
    Last Post: 07-21-2008, 12:03 PM
  3. Pic based Oscilloscope
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 07:48 PM
  4. PC Based Controls
    By zimbricd in forum News Announcements
    Last Post: 12-12-2007, 09:38 PM
  5. dos based cnc software
    By flyingmike in forum Computers / Desktops / Networking
    Last Post: 11-25-2005, 08:29 PM
